Roll On Membrane In Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 10:47 PM   #1
Roll on membrane in shower
I like the idea of the kerdi shower pan kits. Trying to keep costs down, I started looking at the roll on products. The directions I've found show it being used like a traditional liner. Instead of building the preslope>liner>slope>tile. Could I go with one mortar bed slope>roll on membrane>tile? What drains are available without the weep holes?
intense98rt is offline   Reply With Quote
Old 08-01-2013, 10:59 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,624
Interesting thought..... never heard of that drain.... can't imagine how you would get a good seal at the drain...
Heck... Let's invent it.
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 08-02-2013, 02:40 PM   #3
Looking for a drain like this that is made for a mortar bed and doesn't cost $100+.
Old 08-02-2013, 03:54 PM   #4
DIY staff
Rewards Points: 7,174
Go to Latacretes site and look up Hydroban and Latacretes drain system---Bring a wallet---I use their waterproofing for showers and like the products---but good does come at a price---------
Old 08-02-2013, 05:07 PM   #5
Thanks. That's what I'm looking for. I don't understand why more manufacturers don't make them. It would be nice to drive the price down.
Is the only difference between the hydro ban and hydro barrier the drying time?
Old 08-02-2013, 07:51 PM   #6
DIY staff
I never heard of Hydro barrier---in the last couple of years several companies have come out with paint on waterproofing---I have only used Hydroban and red guard---
Hydroban for really critical waterproofing like shower pans--Red Guard for walls and less critical surfaces---
Old 08-02-2013, 08:31 PM   #7
hydro barrier is from laticrete just like hydro ban. Hydro barrier is about half the price of hydro ban.
Old 08-02-2013, 09:41 PM   #8
DIY staff
They have a terrific technical help line----I suggest you call and ask---let us know.
Hydroban is a heavy coating that I have grown to trust----when something works and works well I am slow to try something else.
Old 08-02-2013, 11:32 PM   #9
So Mike..... Not talking Kerdi Shulter..... There is a paint system (Hydroban or redgard type) that you can just use on the preslope (with no top coat for tile) and sufficiently tie into the drain.....????
(I guess everyone around me uses a rubber membrane asembly, or kerdi, or hot mop)
Peter
Old 08-03-2013, 06:50 AM   #10
DIY staff
Yes, there is----I've built three or four showers this way---I am a liner guy---most times.
The showers were all on a slab---I am still not confident enough to use them over frame construction---But that is an application that the paint on membranes are approved for----perhaps some day I will----
Old 08-03-2013, 08:31 AM   #11
THANKS MIKE....... Live and learn every day.....
I just tried googling... no luck....
Do you know of a site/manufacturer that shows the assembly..... like is the preslope same dry sand mix mortor,... thicker than normal preslope,.... just two coats redguard.... and drain assembly. (I did not think above drain assembly was a "paint on" drain assembly... or was it.)
TIA
Best
Peter
Old 08-03-2013, 08:43 AM   #12
DIY staff
Shower Pans for Tile - Linear and Square Drains - Benches, Niches and Seats - Waterproof Shower Kit
You can do a curb and dry pack (deck mud) --then the Hydroban---( I would not trust red guard) or remove the slab in the area of the shower --add the drain and pack a barrier free --roll in shower floor---
Hydroban is a rubbery membrane when finished and is completely water proof---
A schluter drain or Latacrete drain is easiest to use--however, before these were invented a standard clamp drain was used---leaving a hollow opening in the drain area--so the Hydroban could be applied directly to the plastic drain--then the hollow was packed with deck mud before tiling---Mike----
MTN REMODEL LLC (08-03-2013)
Replacing Garden Tub w/Tile Shower on a Slab floor.. Need Help!! cufflinks General DIY Discussions 16 05-20-2013 07:16 AM
Shower Leak Herk_Man Plumbing 10 04-14-2013 05:19 PM
URGENT: Need Help with Shower Leaks myriam0109 Plumbing 8 03-06-2012 10:43 PM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 10:40 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
