Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-20-2008, 01:59 PM   #1
Ripping down Sheetrock?
Friend ask me to rip down all of the sheetrock in a house in a flip hes doing. Someone (or more) broke into the house and vandalized it. There is water damage and physical damage. But what is the safest way to remove, i dont wanna damage any studs or electricals behind. Any advice?
stantheman is offline   Reply With Quote
Old 07-20-2008, 02:25 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Break holes in between the studs, and tear it off the walls using the best tools available:
Your hands.
- Build Well -
Old 07-20-2008, 03:59 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
I agree
IF you never did this before then start by removing all trim from around windows ,doors, floor and ceiling, then proceed to removing light fixtures, and outlet covers. then take Atlantic's advice.
Old 07-20-2008, 08:24 PM   #4
thanks for the help, both of you
i was so into just destroying that i forgot about removing trim and covers
ill prolly have to go and remove each screw too right?
Old 07-21-2008, 05:23 AM   #5
buletbob's Avatar
If your replacing all the electric, then I would not be to concerned about covers or electrical boxes. If the electric is not being touched then yes take the covers off so not to damage the outlet boxes and devices.
Have Fun!!!!
Old 07-23-2008, 08:34 PM   #6
Licensed Contractor
Remove trim, fixtures, plates. Start on one side of the wall, smash a hole in it, use your hands and pull. Once one side of the wall is free of drywall, the backside of the drywall for the opposide side of the wall is exposed. I use a wide tool (I have a demodog that is perfect for this) and pound against the back of the drywall. Comes out faster and in bigger chunks.
Renovator,LLC is offline   Reply With Quote
Lay sheetrock over fireplace with wood burning insert??? amycarlson Building & Construction 13 06-13-2008 09:00 AM
Sheetrock question Vengence Remodeling 4 07-13-2007 11:42 AM
Sheetrock nightmare MRZ Painting 12 05-25-2007 10:23 PM
pipe leak & sheetrock damage santogr General Discussion 2 03-04-2007 02:44 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 09:38 AM
