Ripped Vapor Barrier? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 11:52 AM   #1
Rewards Points: 262
ripped vapor barrier?
I have a few areas in my attic where insulation was cut and pieced around cables running laterally through wall framing. Can I just tape the kraft paper facing with some sort of tape, or do I need to rip out the insulation and install a single piece with the insulation side cut to accommodate the wiring? I would prefer to not waste so much insulation if I can help it. If I can tape it, what kind of tape to use? packing tape maybe?
Thanks.
tpagel is offline   Reply With Quote
Old 12-19-2009, 02:53 PM   #2
Remodeling Contractor
The vapor barrier must be on the warm side during the winter. This is the part you cannot see in an attic. If this insulation has paper facing towards the roof, it is wrong anyway. Either remove the paper of slice many cuts in all of it.
Old 12-19-2009, 03:22 PM   #3
Rewards Points: 262
Sorry. Sometimes I don't give enough information. I am finishing this attic out, to have finished storage space, and hopefully one day, more living space. The insulation is on the kneel walls supporting the long side of the gabled roof (which will be a cathedral ceiling in the future, and is insulated as well). So the kraft paper will be right behind the finished layer of drywall on the walls, and from what I understand, will need to act as the warm side vapor barrier, since I live in New England. So that being said, can I just tape the kraft paper "joint", where the insulation was cut for the wires? I assume I can, because the condition is no different from batts butting up lengthwise in cathedral ceiling rafter insulation, right?
Thanks in advance for your reply
Old 12-19-2009, 03:33 PM   #4
yes then in this case just tape the joints and any tears. Duct tape is good to use
Old 12-19-2009, 04:04 PM   #5
Registered User
Rewards Points: 5,244
"Should the joints be taped?
Johns Manville does not recommend nor require that the joints be taped. Vapor retarders
are area weighted. The small gaps would not allow a significant amount of water vapor
through the wall, ceiling or floor. From: http://www.insulating-products.com/p...lation_FAQ.pdf
Very important that the facing is right against the drywall: http://oikos.com/library/insulating_...lls/index.html
Remember under the knee wall for draft stops: http://www.homeenergy.org/archive/he...95/950309.html
Do a good job: http://www.homeenergy.org/archive/he...99/991110.html
Be safe, Gary
Ripped rattan threads in chair caliwildman Carpentry 2 05-04-2009 07:10 AM
Garage Door Opener Ripped From Door jimparson Building & Construction 15 04-12-2009 08:06 PM
newbie to crownmolding, don't want to get ripped off mariein lz Carpentry 21 03-23-2009 09:25 AM
Site Plans for addition; Am i getting ripped off? RoninGT Remodeling 2 05-21-2007 06:35 PM
Am I getting ripped off??? mvargas Remodeling 15 04-18-2007 02:44 PM
