Rigid Insulation Exposed - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 10:38 PM   #1
I just poured concrete in my crawl space and looking to get the walls insulated. Is it true that you can't use use the rigid insulation and leave it exposed? Looking to get a R-19 value.
timchi29 is offline   Reply With Quote
Old 11-07-2008, 08:39 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Most rigid insulation does not have the proper fire rating to leave it exposed. Look for something that does or plan on covering it. You'd need about 4 inches of extruded polystyrene or about 2-1/2 inches of isocyanurate foam to get R-19.
Old 11-07-2008, 09:48 AM   #3
Thanks. Do you have any suggestions besides unfaced fiberglass? What is the rating or terminology I need to look for and do they make rigid insulation products that will meet code?
Old 11-07-2008, 01:52 PM   #4
Thermax makes a faced iso board that is rated for exposure. I've seen it used inside some metal buildings. I have no idea about cost or availability. I would look for something that says it has a UL "Class A" flame spread rating.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Rigid Insulation on Interior? Pineapple Building & Construction 10 02-29-2008 03:51 PM
Applying rigid insulation Frank63 Remodeling 2 02-28-2008 07:15 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 11:27 AM
