Rigid Insulation Behind Wall Heater? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 10:24 AM   #1
Rewards Points: 91
rigid insulation behind wall heater?
I am thinking about mounting a 1000W 120V wall heater on an exterior wall, in my bathroom. Assuming I have room to do so, would it be possible to put rigid insulation behind the heater's mounting box? Could this be a fire hazard?
debiasio is offline   Reply With Quote
Old 02-21-2011, 07:13 PM   #2
Registered User
Rewards Points: 5,482
Yes, it will be a fire hazard. The smoke when it burns is toxic, the reason fire-fighters first started using oxygen tanks. IRC requires it be covered for fire safety in an attic or crawlspace under most conditions....
Gary
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Polystrene (DOW) Rigid Insulation board - fireproof AndrewF Building & Construction 8 11-28-2010 01:17 PM
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 01:48 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
