Right Size Door For Replacement? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 12:38 AM   #1
Right Size Door for replacement?
Hello:
I have several Kolbe & Kolbe french doors that I would like to replace. I had a contractor (through Lowe's) come out and measure for Pella replacement doors. And, Lowe's is saying that I need to custom order the doors because of the size of the rough opening. Basically, Lowe's is saying that I need a 5' 1/2" W x 7' 11" H frame door for the 5' 1-1/4" W x 7' 11-1/2" H rough opening. Pella has "ready-made" door that is 4' 11-1/4" W x 7' 11-1/2" H for 5' x 8' rough opening.
My question is do I really need to order a custom door or a 1-1/4" narrower and 1/2" taller door not fit into the current rough opening? I don't know how exact the measurements need to be. But, since we don't know the exact rough opening dimensions, it seems to me there may be a chance the "ready-made" Pella door may fit. If I can go with a "standard" size door, that would be great. I have asked the Lowe's employee and I just don't have the confidence in anything he says! Thanks!
SJCJohn is offline   Reply With Quote
Old 12-07-2009, 09:28 PM   #2
Registered User
Rewards Points: 5,516
http://www.pellaadm.com/userdocs/doc...SF_DSSZTAB.pdf page #3 -- ?? From: http://web.pella.com/products/DoorSt.../Overview.aspx
Be safe, Gary
Old 12-08-2009, 02:30 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Before I would order a custom sized door, I'd remove the inside casing and measure the actual rough opening. Then I would avoid using a box store contractor just like avoiding the plague. There are just too many horror stories out there about shoddy work and botched jobs for me to ever say it's a good idea.
Old 12-08-2009, 11:34 PM   #4
Thanks for the suggestion. I was hoping to avoid having to take the inside casing off in case we put off the project.
Old 12-08-2009, 11:53 PM   #5
Originally Posted by GBR in WA View Post
Thanks for the links. The first site has a lot of good information.
Old 12-09-2009, 04:42 AM   #6
Too Short? Cut it Again!
I am sure some of them are just hungry and do good work but I agree. Ask around, get somebody with references and that has done similar work for others in your hood, for friends, etc. I definitely agree you should not order custom doors without knowing the exact dimensions of the opening. I would take the casing off.
Old 12-09-2009, 07:43 AM   #7
MJW
Here's a little secret........The "contractors" from the box stores are just subs that can't get their own work.
Get a real contractor for the job if you want it done correctly.
MJW is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
duct work size justmefixin HVAC 2 09-20-2008 06:59 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
