Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-25-2010, 03:56 PM   #1
Retrofitting Windows to Meet Egress Requirements
Hello-
This is probably an odd question, but I thought I would give it a shot.
I installed windows without a permit and, of course, got caught (but, frankly, I had no idea one was required, nor did my contractor). In two bedrooms, none of the windows meet the 5.0 square feet requirement (one's at 4.92 and another is at 4.3.) The windows are in, and re-framed, so it would be prohibitively expensive to eat the cost of the window, and pay to have it re-framed and re-installed.
One solution that I'm contemplating is to trim the plastic sash stops that slide up and down to restrict the range of sash movement to allow the bottom sash to slide up further. Or, conversely, trim the bottom plastic trim, too. I only need approximately 2-3 inches total to meet the egress requirements.
Has anyone done something like this before? Is this an absolutely terrible idea?
Thanks.
mgarland is offline   Reply With Quote
Old 05-26-2010, 06:52 AM   #2
Permits not required here unless the opening is modified. Egress from basement living or sleeping spaces is required and needs to be 5.7sf IRC code. Other bedroom windows are usually not an issue in existing construction, since they are usually large enough for a person to fit thru.
Old 06-05-2010, 09:11 PM   #3
Did the old windows meet the requirement? Is it even possible to find a window that meets the requirements and fits in the existing Rough Opening?
If the answer to both is no then it's time to sit down with the building department for a discusssion. Of course, they'd be a lot more reasonable if you got the permit first. But, nonetheless, it seems reasonable for you to question why the City allowed the home to be sold to you without proper egress windows, and whether it is reasonable now to make significant structural changes to meet the requirements or whether grandfathering is appropriate.
Installling Basement Egress Windows JohnnyB Building & Construction 2 04-11-2010 08:15 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Windows: RO sill height and egress question. iMisspell Building & Construction 3 10-25-2008 01:55 PM
Basement Egress Windows rescueswimmer General Discussion 3 07-18-2008 08:49 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
