Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-27-2010, 10:35 AM   #1
Retrofitting Vintage doorknobs on bathroom/bedroom doors
All,
I recently purchased vintage style, inactive, doorknobs from Anthropologie that I would like to retrofit on existing doors in my bathroom and bedroom.
The problem:
The hole in the door (where the latch mechanism and doorknob were secured) is larger than the rosettes that came with the vintage knobs.
The vintage rosettes are about a 1/4-1/2" too small and thus cannot fasten to the door directly.
Does anyone have experience retrofitting vintage knobs on a modern door? The solution seems like it would be relatively easy, but every where I have been (Lowe's, Ace, Home Depot, etc.) is either confused by the problem or simply don't have an answer.
Any help would be much appreciated!!!
biggabush is offline   Reply With Quote
Old 01-27-2010, 10:36 PM   #2
firehawkmph's Avatar
Biggy,
You need to fill the current hole in and start over. If you are painting the doors, should be no big deal. If the doors are stained, could be tougher.
You may get lucky and be able to cut some fillers with the next bigger size hole saw. A better way is to find someone in the area with a small wood lathe and have them turn some pieces to fill the holes. Glue them in place and redrill.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
