Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-02-2008, 11:15 AM   #1
Default Retrofit Window Installation
Hello
I've purchased my retrofit windows and am getting ready to install. My existing aluminum window frames have drip edges top and bottom which I removed with tin snips. The aluminum frame still sticks out from the stucco about 3/16" all around. The plastic fin of the retrofit window has a return of about 1/16". When I place the window in the opening I have a gap all around of between 1/8" to 3/16". Do I need to grind or cut the aluminum frame so the plastic fin contacts the stucco or can I fill this gap with caulk? If I need to trim the aluminum, what is the best method?
typerr is offline   Reply With Quote
Old 10-22-2009, 06:45 PM   #2
Bump
I'm thinking of DIY retrofit windows too, and I have the same issue...could anyone share their experiences???
pcl586 is offline   Reply With Quote
Old 10-22-2009, 07:18 PM   #3
Plastic fin? Are you referring to the nailing fin?
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 10-22-2009, 09:46 PM   #4
Originally Posted by pcl586 View Post
Bump
I figured it out when I did my windows last year..... You definatly need to trim the aluminum. I used a sawsall with a long metal cutting blade. Buy lots of blades and wear good ear & eye protection. You'll also want to hang a sheet or something inside the window opening as the chips go everywhere. By the 15th window I had Ninja level sawsall skills.....
It was a royal pain in the but worth it as the windows came out great.
Old 10-28-2009, 01:47 PM   #5
thanks! i only have 7 windows so i may not attain the Ninja skills by the time i'm done
More On This Topic
Replacing your windows is one way to boost the value of your home, especially if the new windows are more energy efficient. One of the popular styles of replacement windows is vinyl retrofit replacement windows. Read this eHow to learn how to trim... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
In this clip we're going to talk about the proper service procedure to retrofit your vehicle's air conditioning system from R-12 to 134-A and recharge the system. In this step we're going to talk about the tools required in order to properly retrofit and... Read More »
Everyone knows to close the door behind them in the winter. But sometimes that isn't enough. General wear and tear on your door can create gaps that let cold air in and cost you money. Fixing these is relatively easy, and a little time and money spent to... Read More »
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
Window Installation Guide Pondo13 Building & Construction 1 07-18-2008 07:49 AM
Window installation cost only. Changeling Building & Construction 18 06-30-2008 04:01 PM
help with window installation please hammer Carpentry 1 02-28-2008 10:19 AM
Window Well Installation Bill46 General Discussion 1 04-03-2007 06:49 PM
Bay window installation skinut2234 General Discussion 0 11-02-2006 11:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
