-   -   Retrofit Window Installation (http://www.diychatroom.com/f15/retrofit-window-installation-26137/)
typerr 09-02-2008 09:15 AM
Hello
I've purchased my retrofit windows and am getting ready to install. My existing aluminum window frames have drip edges top and bottom which I removed with tin snips. The aluminum frame still sticks out from the stucco about 3/16" all around. The plastic fin of the retrofit window has a return of about 1/16". When I place the window in the opening I have a gap all around of between 1/8" to 3/16". Do I need to grind or cut the aluminum frame so the plastic fin contacts the stucco or can I fill this gap with caulk? If I need to trim the aluminum, what is the best method?
pcl586 10-22-2009 04:45 PM
Bump
I'm thinking of DIY retrofit windows too, and I have the same issue...could anyone share their experiences???
jaros bros. 10-22-2009 05:18 PM
Plastic fin? Are you referring to the nailing fin?
typerr 10-22-2009 07:46 PM
Originally Posted by pcl586 (Post 344170)
Bump
I figured it out when I did my windows last year..... You definatly need to trim the aluminum. I used a sawsall with a long metal cutting blade. Buy lots of blades and wear good ear & eye protection. You'll also want to hang a sheet or something inside the window opening as the chips go everywhere. By the 15th window I had Ninja level sawsall skills.....
It was a royal pain in the :censored: but worth it as the windows came out great.
pcl586 10-28-2009 11:47 AM
thanks! i only have 7 windows so i may not attain the Ninja skills by the time i'm done :)
