Retro Fit Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 01:26 AM   #1
retro fit window
i forgot to look on the outside of the house when i measured for a new window. the old aluminum window frame stays in and the new retro window is put in from the outside cause it's a flush fin are on the outside and then gets screwed on the inside sides and problem is i measured on the inside of the house and didn't notice the brick 1 inch below the window sill on the outside. can i cut the fin 1/2 the width on the bottom.or am i going to cut the top aluminum frame out and 1 inch into the header.?
quadcccc is offline   Reply With Quote
Old 10-08-2010, 10:29 PM   #2
Rewards Points: 5,336
It sounds like you're putting a new construction unit into an opening with the old frame in place. I don't know what a "retro" window is. Windows are either replacement or new construction.
What covers the nailing flanges? Is this a brick house? If it is, you can use masonary clips to hold the window in.
See if you can post a photo of both the new window and the opening it's going into.
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
