Retile Shower Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 12:33 PM   #1
bryanp22's Avatar
Rewards Points: 290
Retile shower ceiling
My home is a colonial and the shower is against the ceiling where it is slanted slightly so the ceiling of the shower is tiled. Any recommendations for tiling a ceiling? Do I need to worry about the tiles falling after placing them in thinset?
bryanp22 is offline   Reply With Quote
Old 03-13-2013, 09:01 PM   #2
Rewards Points: 236
i have never done a ceiling . but i have walls and floors. removing a tile right after setting it, can be a task, i had to use a screwdriver to pry it up. so i don't see them falling off, if done correctly.
Fix'n it is offline   Reply With Quote
Old 03-13-2013, 09:09 PM   #3
Rewards Points: 944
In that Circumstance, you may have to worry more about the tile creeping down.
Last edited by oh'mike; 03-14-2013 at 07:35 PM. Reason: Damned spell checker got you!!!
cleveman is offline   Reply With Quote
Old 03-14-2013, 02:22 PM   #4
Rewards Points: 744
Originally Posted by cleveman View Post
In that circumcision, you may have to worry more about the tile creeping down.
Uh, got something on your mind?
Seattle2k is offline   Reply With Quote
Old 03-14-2013, 07:37 PM   #5
DIY staff
Rewards Points: 7,174
Done right, they will stay put---however, sliding can be an issue ( as stated above) little finishing nails might be needed to pin the tiles down ,if spacers don't do the trick.
Old 03-14-2013, 08:49 PM   #6
Rewards Points: 258
i read some where that you should back butter the tile, and then do a circle from the center of the title to the edge, so that when you push the tile against the ceiling it makes a slight vacuum.
redman88 is offline   Reply With Quote
shower stall ceiling nickmick Kitchen & Bath Remodeling 8 08-29-2012 04:45 PM
custom tile shower ceiling maljeff Drywall & Plaster 1 08-21-2012 10:07 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
tiling a shower ceiling.... anedoll Remodeling 1 01-01-2007 07:04 AM
