Restaining Handrails - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2008, 04:24 PM   #1
Restaining handrails
Our floor refinisher is ready to sand and stain floors and stairs but will not do the newels or handrails. What is the best plan: 1. Disassemble, sand stain & reassemble. 2. Sand & stain in place. 3. Take apart & replace newels & handrails with newly stained ones ? (The ballusters will remain white.) See pictures
stan 41943 is offline   Reply With Quote
Old 05-31-2008, 06:27 PM   #2
Registered User
Termite's Avatar
Chances are, you won't have much luck disassembling the handrails and newels without really tearing into things. Most ballusters are glued, and some are even nailed.
Are you changing the stain color? Or are you just wanting to give it a new clear coat?
If you're changing the stain, good luck. That is a heck of a job, especially if you're working on the parts in place. If you just want to refinish the clear coat, you can give everything a light sanding with 400 grit to remove any scratches and to roughen the surface of the existing clear coat. Use a tack rag to remove all dust, then re-apply a couple coats of polyurethane, sanding with 0000 steel wool or very fine sandpaper between coats.
Old 05-31-2008, 09:42 PM   #3
Thanks KC - yes the wife wants to change stain color. I'll plan on disassembly & 90+ % probability of having to replace newels & handrails. Can't quite figure out how the newels are attached to the floor. Bolted?
Old 06-01-2008, 07:45 PM   #4
Registered User
Termite's Avatar
The newels could be installed a number of ways. I would image that they're fastened to the floor framing from the side, or at least fastened to the stair stringer. There are a few proprietary systems as well. In order to be pretty solid, they usually project below the floor level.
Be sure to take out the newel before your floor is refinished, just in case you damage a piece of hardwood in the process.
I'd also suggest taking the railing apart in as few pieces as possible and keeping it until you're done putting the new one in. That way you have a nice template to work off of!
restaining deck, new/old wood... Mr. Michael Painting 11 11-19-2012 01:35 AM
Granite Countertops and Restaining kennykenny Remodeling 64 05-02-2009 12:15 AM
restaining cherry cabinets royal rooter Painting 1 03-08-2008 01:46 AM
restaining window trim ciera Painting 11 11-12-2007 02:29 PM
How do you locate proper location for step handrails?? justdon General DIY Discussions 1 09-09-2007 08:10 AM
