Resilient Channel For Basement Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2007, 02:50 PM   #1
I am considering using Resilient Channel in my basement ceiling insted of wood strapping to aid in soundproofing. Has anyone else tried this? If so, where is a good place to get it from. I have been all over the internet, there are different kinds and a wide range of prices.
Any advice would be great.
Thanks,
Stingray is offline   Reply With Quote
Old 04-14-2007, 03:18 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks,
We have used it many times in Multi unit dwellings (Apts, condos, etc...)
Your best bet is to find a local Drywall Supplier that stocks steel framing. If they have steel framing (which they all do)....they will definitely have resilient channel.
It's a great way to change the sound waves and increase your soundproofing. The best method is a single layer of 5/8" sheetrock. Then the resilient channel, then another layer of 5/8" sheetrock.
Another option to consider - you could look into 1/2" 'quite rock'. The costs come out to about the same when you factor in the time savings if using just the 1/2" quite rock (no channel or double sheetrock layers).
Link:
http://www.quietsolution.com/
- Build Well -
Old 04-15-2007, 10:46 PM   #3
Thanks,
HD carries it, remember most of the sound travels in your ducting if you have forced air. Weight the effort......
woodmagman is offline   Reply With Quote
Old 04-16-2007, 05:10 AM   #4
Are you sure HD carries it? I know they have 'high-hat' steel channel...But did they start carrying resilient channel (acoustic rated channel: RC-2 for ceilings and RC-1 for walls)?
FWIW - Here's a link on more information about using steel RC channel for sound deadening:
http://www.soundproofing.org/infopages/channel.htm
- Build Well -
Old 04-16-2007, 11:36 AM   #5
I do have a forced air system, what would be the proper way to soundproof the ducting?
Old 04-16-2007, 01:21 PM   #6
Links:
http://www.acousticalsurfaces.com/hv...t_lag.htm?d=26
http://www.soundsuckers.com/duct.htm#duct
http://www.allnoisecontrol.com/products/WrapBarrier.cfm
http://www.soundseal.com/barricade/b...uct-wrap.shtml
- Build Well -
Old 01-16-2010, 10:55 AM   #7
You can find them at www.soundrite-acoustics.com, you would only use resilient channel when you're building a sound room or a recording studio. Other wise place Roxul between the 2 x 4's and mass loaded vinyl over the studs with plaster board as a final layer.
John M12 is offline   Reply With Quote
Old 02-07-2010, 12:14 PM   #8
Soundproofing Guy
Rewards Points: 158
IN general, you only ever want one air cavity. So all channels, clips furring, etc would go on the joists (or studs), never on existing drywall.
This has been specifically tested and studied at length: http://www.soundproofingcompany.com/...e_leaf_effect/
Ted White is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
lowering ceiling to 8 feet level mirico Carpentry 4 10-24-2009 08:24 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 03:47 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-24-2006 11:23 PM
