Replacing Windows In Stucco House - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 01:13 PM   #1
Replacing Windows in Stucco House
I just bought a house in Moreno Valley, CA. Most of the windows have been replaced except for these two. One has some sort of wood trim on the outside and is an Aluminum window that does not open. I am not sure what kind the other window is, but it opens but has No trim on the outside. Below are pics.
^^^This is the aluminum window. I am wondering, If I just rip the wood trim off of the outside, can I just pull all the nails and crap out and pull out the window, then replace with one of identical size? Will the inside sill be messed up or damaged? Will the stucco be damaged? (That's my wife in the reflection btw)
^^^^^Here is the regular sliding window. This one has no siding/trim. So to remove it am I going to have to bang out the stucco, remove the mounts to the framing, put in a new window and re-stucco? I am again worry about the interior window sill.
Please don't laugh at how crappy my house looks, I bought it for $64K and haven't even moved in yet.
I searched for guides on the internet and could not find anything that was very informative.
LDSGJA is offline   Reply With Quote
Old 07-03-2010, 09:25 PM   #2
jlhaslip's Avatar
Rewards Points: 2,748
Use a grinder with a diamond wheel to cut away the stucco around the windows. Cut away as much stucco as you need to remove the existing window.
Then replace the windows with the new ones. You may need to tweak the stucco removed to allow for the new nailing flange.
After installing, add drip edge and mastic to suit and then trim out using wood or other trim pieces.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
problems with replacing doors in stucco house darsunt Building & Construction 3 08-13-2011 11:56 PM
Stucco Fins vs. Nail Fins on Stucco House xquercus General DIY Discussions 5 01-25-2009 04:44 PM
Replacing Glass In Windows OVRMYHEAD General DIY Discussions 1 04-26-2007 06:07 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
