Replacing Windows And Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-02-2008, 07:25 PM   #1
Question
Replacing windows and siding
I decided to replace windows and quickly realized that I had to replace the siding as well. My issue is this. As I removed the old paperlike siding the only thing behind it was the frame of the house and fiberglass insulation between each section of frame. Do I need to put plywood first, then Tyvek housewrap, and then the siding or can I just put the Tyvek housewrap and siding over that?
ramiree is offline   Reply With Quote
Old 07-03-2008, 12:43 AM   #2
747
registered
747's Avatar
Rewards Points: 534
4x8x5/8 sheathing osb. ITs cheaper then plywood and will work fine. Then do the tyvek. Make sure you get some tyvek tape to tape around the windows good and the overlapping seams of the tyvek.. Now you can put the vinyl up. Snap chalk lines on all the studs. Make sure you nail into studs not sheathing. Make sure you don't nail tight. Leave a little expansion gap about the width of a penny should do. To be specific 1/32 of a inch. Actually i think thats the width of a dime.
Best manufacturers of vinyl in my oppion Certainteed or Crane.
747 is offline   Reply With Quote
Old 07-03-2008, 11:39 AM   #3
Registered User
Termite's Avatar
7/16" OSB will work fine for this application. 5/8" is overkill. Nail the edges (top, sides, and bottom) with 8d nails at 6"oc, and the field at 12" oc on the studs. I've inspected thousands of homes, and have never seen one with 5/8" on a wall.
Research Tyvek's entire system and follow their instructions to the letter.
Old 07-03-2008, 11:44 PM   #4
747
registered
747's Avatar
Rewards Points: 534
i prefer overkill. But you can get by with 7/16 osb.
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
Replacing Old Windows pyrogen74 Remodeling 1 02-09-2006 06:53 PM
