Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-17-2010, 12:25 PM   #1
Replacing windows - masonry construction
I have 50yo house with brick walls. There is gray cement block inside and brick outside. I also have 2x2 with insulation under plaster.
I want new construction windows.
Window sills on outside sloped down and so is my window frame bottoms. Everything looks good and solid.
Original wooden windows been there and right now only few rotten, others have cosmetic issues like 20 layers of peeled paint and just driedout/deformed so they can't be opened/closed properly.
I wonder which way should I go. I like wood and I don't think painting outside will be a big deal. Is there companies that can make same kind of wood window for me? The only caveat is that I want casement window.
Single pane is 38" wide and standard size for most casement windows don't go higher then 36"
Does anyone have suggestion on proper installation method and maybe manufacturer to look at for wood windows?
Thanks!
katit is offline   Reply With Quote
Old 05-17-2010, 08:36 PM   #2
Get windows based upon the Masonry Opening sizes. The manufacturer will have instructions on how to install. I can't recomend any particular manufacturer. Unless you get lucky and the MOs match stock windows you'll need to go with a manufacturer who will make sizes to order.
Old 05-18-2010, 09:01 AM   #3
http://www.woodwindowalliance.com/fi...STALLATION.pdf
This guide may help.
stuart45 is offline   Reply With Quote
Old 05-18-2010, 12:39 PM   #4
Branden's Avatar
Just out of curiosity, why do you want new construction windows instead of replacement windows?
Branden is offline   Reply With Quote
Old 05-18-2010, 01:52 PM   #5
Branden,
Good question.
I don't want any glass area to be lost. And I don't like how it looks with thick frames, etc. I understand it's easy but I want it to be done right.
New construction vinyl windows twrenfrow Building & Construction 1 11-11-2009 06:58 AM
Replacing Double-Pane Windows RSJ0316 General Discussion 1 09-16-2009 08:31 AM
replacing box in wall with new construction type DIYGST Electrical 15 02-24-2009 12:05 AM
Replacing 100 yr old windows Minden General Discussion 3 07-11-2006 12:58 PM
Replacing Old Windows pyrogen74 Remodeling 1 02-09-2006 07:53 PM
