Replacing Window Frame
11K views 6 replies 2 participants last post by  SebasC
I Have a problem my window frame is starting to rot (included picture) i want to replace it but i have no idea where to start. It is a mobile home and i want to replace the whole frame the window is in.
Kinda hard to explain to someone over the "net" but I will give it a try.
You will have one of the following framing techniques for windows. The light brown is where you will need to check and make sure that you have taken care of all the rot etc...
Take the window out and start demoing, carefully. Once you get into it, you will see what you need to replace and what can stay.
Framing 1:
Detail:
#5 ·
Yeah we started a little bit to see how it looked but the whole outer and inner wall to our mobile home are rotten and falling apart (especially around the window) now we are once stuck with a dilemma. Will we have to take out both outer and inner wall and siding on the outside? or do we hire a professional and what do we look for when looking for a professional?
