Replacing A Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 06:15 PM   #1
Rewards Points: 14
Replacing a window
Hi All,
I am going to replacing a current window that is a picture window (single plate of glass) that is rough opening of 8.0' wide and 5' high. The replacement window will be a little smaller. The rough opening of the new window will be 7'-10 3/4" for the height. To make the rough opening smaller I was going to laminate (2) 1/2" plywood strips 3 1/2" wide and the lenght of the sill and then fasten and glue the 1" lamination to the sill.
Does this sound reasonable to reduce a rough opening by an inch leaving 1/4" space for alignment and shimming? Do I need to totally reframe the window.
I live in south florida
Thanks in advance.
whattodo is offline   Reply With Quote
Old 03-07-2010, 09:51 PM   #2
Why mess with the plywood? Just attach a 1x4 to the bottom of the rough opening to take up the space. You will still have a 1/2" to level/shim the window.
ptraz is offline   Reply With Quote
Old 03-08-2010, 05:23 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
it sounds ok but...
south florida has some very stringent codes regarding windows i believe
hopefully a contractor from that area will respond or you can check with your building dept.
Tom Struble is offline   Reply With Quote
Old 03-08-2010, 06:51 AM   #4
how you getting 7' tall in 5' tall opening
The older I get the better I was
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replacing panes in a Pella window Richo Building & Construction 5 09-11-2009 09:20 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
