Replacing Tile In Bathroom Floor (2x2 Tile) - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 02:48 PM   #1
Rewards Points: 29
Replacing tile in bathroom floor (2x2 tile)
Hi i am replacing two sheets of 2x2 tile that were not of the same dye lot.
( the tile retailer has claimed that i should have noticed prior to install and will not help)
I have removed all the grout on the floor pan and have removed the two sheets of tile.
When replacing the tile with two new sheets of the corect dye lot can i use the thinset to cover the imperfections of the concrete floor pan which now is slightly pitted from the removal of the original tile?
Alternatively i can mix another batch of limeless mortar for the base to skim.
Paul
Paul8434 is offline   Reply With Quote
Old 09-05-2011, 06:06 PM   #2
DIY staff
Rewards Points: 7,174
The thinset should work fine for what you described.
The tile stores can be real butts about mixed lots---always beware of open boxes or loose pieces.
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
Installing towel hanger shelf through bathroom tile and drywall zeramuas Kitchen & Bath Remodeling 3 01-14-2011 07:01 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 12:38 AM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 06:18 PM
