Originally Posted by wizardofza
....We have a spare front indoor room that the POs added, where an outdoor patio originally existed. It's installed over a concrete slab. There's no room above it - it's only one floor....
If the foundation of that room "is" the old patio, then be prepared for issues. Read on.
....I also don't think there's insulation under the subfloor because between the joints of the plywood you can just feel the cold air coming up. And living in Buffalo, it can get cold here in the winter....
There may not be insulation there, there may also be inadequate insulation (not enough) -installed. There may also be openings/gaps somewhere, that is allowing air to draft in from the outside.
....As the first step of the remodel of this room I want to redo the subfloor. What I'm planning on doing is ripping the entire floor out and replacing the sleepers with PT 2x4s 12" OC and then putting 3/4" tongue in groove on top of that....
I started out saying that "if" the foundation of that room "is" the "old patio": then be prepared for issues. Such a "foundation" (and I use that term loosely in this context) may only be several inches in depth. As such, anything attached to it, would be subject to frost heaves, expansion/contractions, etc (in other words = seasonal movement).
Be prepared for continued squeaks and floor material flexing.
In NY, a proper living space should be built on top of 4' deep frost walls.
If you plan on going forward with the project: Use PT sleepers attached with treated or galvanized fasteners. Glue the 3/4" T&G down to the sleepers and use screws to secure. Make sure that you use the proper "treated", stainless, or galvanized - screws/nails for the PT - as the ACQ treatment in PT will corrode standard "bright" fasteners/nails.
.... What type of vapor barrier would be good to use in this type of application?...
Install a poly vapor barrier over the PT and the insulation (between the 3/4" T&G and the PT sleepers).
Alternately, you could install a layer of Ice & Water shield directly over the concrete slab, and attach all other materials over that.
....What type of insulation would be good to use in between the sleepers...
Ridgid Foam Board
....OR, can I just get away with using 2" foamboard and putting the sub-floor directly on that using masonry screws to secure it to the slab (ala Holmes on Holmes)? Or is this just good for below-grade slabs (i.e: basement redos)?....
You should use the maximum amount of foam for the space's thickness. There is no need to use screws to attach it. You could simply place it onto the concrete.
Alternatively, I would suggest using a basic adhesive, and spray foam (canned) insulation around the edges - to create completely sealed areas.
Lastly: Make sure that the PT sleepers and the 3/4" PT subfloor are fully dried out (ACQ treatment fully cured), before you attach anything else to it.
ACQ PT shrinks over time, as the ACQ treatment cures & dries out.
Realize that the area may never be completely movement free.
