Replacing Soffit - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 10:54 AM   #1
replacing soffit
im replacing the rotted soffit on my garage with vinyl 12" vented
how do i place this?
it says to use one stick of j channel and then nail my soffit to the fascia and cover it with vinyl..but im not using vinyl fascia im using wood
psd7.3 is offline   Reply With Quote
Old 07-16-2010, 12:20 PM   #2
kwikfishron's Avatar
Rewards Points: 782
You need to install a 2x2 nailer to the inside of the fascia and have the soffit recessed a bit.
Post a picture if you can.
kwikfishron is online now   Reply With Quote
Old 07-16-2010, 02:53 PM   #3
Registered User
Rewards Points: 526
Location, location, location..... http://www.floridadisaster.org/mitig...ks/soffits.asp
Be safe, Gary
Old 07-30-2010, 02:57 PM   #4
i ended up buying my 12" vinyl soffit. I got 1"x6" fascia and 6" fascia metal..my question is on the ends how do i box it in? does my j channel go on the ends too? and my wall is block with brick on the top course so should i tapcon my j channel to the block?
thank ya
Old 07-30-2010, 05:16 PM   #5
Rewards Points: 782
You don’t want to attach the J directly to the block. You should attach a 2x2 to the block and then nail the J to that. The J needs to be able to expand and contract so you don’t nail it tight.
As far as boxing in, if you mean the transition between a level run of soffit at the eaves into the gable end, you would frame that in with wood and wrap that end in aluminum.
Once again a picture would be helpful.
Old 07-30-2010, 05:25 PM   #6
thats wat i dont understand if i put a 2x2 block in then i would only have 10" between the j channel and fascia with a 12" wide piece of soffit
Old 07-30-2010, 05:38 PM   #7
Rewards Points: 782
The 2x nailer goes above the J, the J is still in contact with the block It’s just not attached to it. It’s attached to the nailer above.
Old 07-30-2010, 06:07 PM   #8
the Musigician
DangerMouse's Avatar
This is strange to me....
I used "F-Channel" and aluminum fascia for my vented soffits.... standard 6" wood fascia, drip edge, etc. Where would J-Channel come into play?
Just curious....
DM
Old 07-30-2010, 07:08 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
its just a different attachment method DM
Tom Struble is offline   Reply With Quote
Old 07-30-2010, 07:09 PM   #10
its just a different attachment method DM,the f channel is nailed to the wall the j is nailed to blocking
Old 07-30-2010, 07:14 PM   #11
the Musigician
I get it, upside-down J on 2x2s... hmmmm, you mean I could used vinyl???? lol
DM
Old 07-30-2010, 07:39 PM   #12
I used J channel for my soffits...I think
I also took the wood out & used vinyl instead
Bugs can't chew thru it like they did the wood
Old 07-30-2010, 07:46 PM   #13
personally i never use vinyl soffit ji either buy aluminum or bend it myself
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 09:01 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 06:36 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
