Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-31-2009, 10:30 PM   #1
Default Replacing Sliders with French Doors
Hi,
We are in the process of beginning some new projects. Our house is a rambling cape, and we have a sunken family room with nine foot ceilings that currently has two sets of sliding doors to our deck, each unit 8 feet wide. We are going to have french doors installed, with applied grilles to simulate the look of divided lights. We are considering transoms, but have been advised that the header needs to be moved up in order to do that, which will allow us to have twelve inch transoms above each of the six door panels,
An alternative to the transome is to get doors that are taller than standard. My guess is that the header will still have to be moved up to accommodate the new height, but I am not sure. I suspect that the cost of taller doors would be less than standard doors plus transoms, and that installation would be less complicated, and hopefully less expensive.
Here is my question: Does anyone have opinions on which alternative would look better? On the one hand, I love the look of transoms. On the other hand, I worry that perhaps the transom look with be to this time period what the palladian window was to the 80's/90's. Taller doors might be a more classic look, but not sure that I want to give up on the transoms!
Thanks in advance for your input. By the way, the doors we are considering are Andersen. We were tempted to consider Marvin, but they are much more expensive. We especially like the ones that have a large panel on the bottom rather than the ones that have glass all the way to the floor.
ElizaWhyza is offline   Reply With Quote
Old 03-31-2009, 10:55 PM   #2
Man of many hats
wrangler's Avatar
The first thing I would check is to find out exactly what clearance you actually have. It very well could be that the header already has 8' of clearance and the wall is built down to frame in the current doors. 8' tall doors are usually quite a bit more expensive than standard doors. Not sure what kind of view you have outside, but you will be losing much of that view if you go with a paneled door versus full view. To get a feel for the difference, you could paper over the bottom of your current sliders to see if this has any bearing on your choice of door style.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 04-01-2009, 12:26 AM   #3
The Op has decided on the Andersen French doors as opposed to the permashield doors. The view, for all intents and purposes is the same.
I used the 6' wide French doors with the archtop window above in the gable bumpout of the kitchen. It was taller then 8'.
I don't think either scenario will fit in your room if it has 8' ceilings.
Ron
Tags
french doors, replacement door, transom
More On This Topic
Doors can be tricky simply because they have to look really good. Whether inside or outside, doors are one of the most visible areas of the house. They're usually well lit so every little drip and brush mark will show up. Use really good brushes for door... Read More »
The first Hudson rolled off the assembly line in 1909. The car was named after its benefactor J. L. Hudson. What is unique about Hudson cars is the company's shift from buying engine parts to manufacturing them in-house--Hudson cars were built with their... Read More »
How to Tie a Transom Knot
How to Tie a Transom Knot by Expert Village
Now I'm going to show you the Transom knot. The transom knot is a great knot to use if you want to put two pieces of anything together at a perpendicular angle. So if we look down here, you can see that I have my two pieces of wood, and then I have my... Read More »
Okay here I am in the interior, the obvious areas you look at the door panels see the condition of those, you look at the dashboard, you look at the headline, you look at the seats, you look at the front back of the seats, the back seats, the carpeting... Read More »
Hello! My name is Jason. I am talking on behalf of expertvillage.com. Now after you do the hood, the next step you want to do is inside the door panels and between outside the door panels over here. People actually think this is a part of the interior of... Read More »
Installing french doors in a load bearing wall johnsan Building & Construction 6 01-03-2009 06:59 PM
Pair of French Doors/ one is warped nyc1dxo Carpentry 8 04-28-2008 09:10 AM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 03:27 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 09:19 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 12:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
