Replacing Sag In Ceiling-plaster Behind Sheetrock - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 12:48 PM   #1
Replacing sag in ceiling-plaster behind sheetrock
I just recently bought a house that had a leak in the roof at one time. The leaks made its way down to a bedroom and caused a little sag in a 4x4ft section of the ceiling. My thought was that I could cut out the sag and replace the sheetrock in that section. Once I got in there I found that there was plaster above the sheetrock. My question. Will I still be able to replace just that section or will the entire room's ceiling need to be replaced? Any thoughts on where to go from here?
cwalker33 is offline   Reply With Quote
Old 09-29-2009, 09:17 PM   #2
Too Short? Cut it Again!
I would take down the plaster where the ceiling was sagging to get it out of your way. Fir out the structure for the patch so you can match it up with the existing ceiling. Screw or nail it in place. Tape and mud the seams and you should be good to go.
Old 10-03-2009, 09:48 AM   #3
Drywall contractor
Rewards Points: 1,070
Good advice. The integrity of the plaster was likely compromised by the water also. If so, it wouldn't be wise to cover it back up.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Water damage to ceiling sheetrock Go4EVA! General DIY Discussions 8 08-29-2009 09:25 AM
peeling paint on plaster ceiling mspdet Painting 9 12-13-2008 08:45 PM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
Mating sheetrock to textured ceiling atlfiveo Building & Construction 2 02-05-2007 11:43 PM
