Replacing My Bathtub And Shower Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 01:50 PM   #1
Replacing my bathtub and Shower tile
Ok my house was built back in 1977. I'd like to start a few remodeling projects so that i can sell my house in a year or 2. I have a broken soap dish with a handle that is starting to turn black. i assume this is from water seeping in. I don't want to pay for someone to fix or replace this. but i would like to know what is all involved with replacing the bathtub, and tile. And if its possible to they may spa tubs to fit in a standard bathtub stall?
Blackldr is offline   Reply With Quote
Old 08-19-2013, 02:16 PM   #2
DIY staff
Rewards Points: 7,174
This is a subject frequently discussed here---
You might look in the tile section and follow some of the older threads---Jim F has a good step by steps thread---also Big Jim---
Gutting the tub area and removing the old tub is not all that difficult---
Adding a new tub and drain set is well within the ability of a person with good mechanical skills.
Adding a new shower mixing valve requires soldering skills---
Spa tub? If you are speaking of a whirlpool, you need to be able to run a dedicated electric circuit with GFCI protection----
Tiling? There is a world of info right here on proper technique---
Old 08-19-2013, 03:02 PM   #3
thanks. i've been lookin on Youtube for video instruction, cause i like to see what to do before i try it, and I didnt express that.
Old 08-19-2013, 06:18 PM   #4
DIY staff
Ask here and post a link to any videos that you like---there is a lot of bad instructional videos---so be careful---some are failures waiting to happen.
We can walk you through any part of a tile or bath job---Mike----
Old 08-19-2013, 08:29 PM   #5
Rewards Points: 150
Well, I think it depends on how experienced you are. Im a complete novice and in the middle of renovating a bathroom. Im lucky it was built in the early 80s so nothing to crazy. Its a big job for someone unskilled but it can be done. Prepare to spend a lot of time and buy a lot of tools.
Arsinek is offline   Reply With Quote
The Following User Says Thank You to Arsinek For This Useful Post:
oh'mike (08-19-2013)
Installing shower unit inside bathtub mlinpdx Plumbing 2 11-29-2012 01:03 PM
Need to add shower to existing bathtub Tmack_5_0 Plumbing 4 04-05-2011 12:08 PM
Converting Bathtub to Shower enkay18 Kitchen & Bath Remodeling 2 07-14-2010 03:05 PM
convert bathtub to shower argos Plumbing 10 02-20-2008 12:53 AM
Replace Bathtub w/ Shower Only mahjohn Building & Construction 3 07-06-2006 09:11 AM
