Replacing Mono Posts With New Ones, How To? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-26-2007, 12:03 AM   #1
weekend warrior
Rewards Points: 150
replacing mono posts with new ones, how to?
One of my mono posts has, literally, rusted all the way through. The others can't be much better.
I have replacements, but I was wondering how exactly to install them. What sort of pressure do you apply, is there some sort of torque spec? Or do you just snug it up?
johnny331 is offline   Reply With Quote
Old 09-26-2007, 06:32 PM   #2
Rewards Points: 5,336
What's a mono post? I never heard the term before.
Ron
Old 10-01-2007, 05:54 PM   #3
weekend warrior
Rewards Points: 150
Old 10-02-2007, 09:15 AM   #4
We call them lolly columns. In this case, concrete filled lolly columns. The lag bolts just need to be snugged up. The weight of the house kind of keeps them in place. After a month or so check them .
Ron
Old 10-02-2007, 11:53 AM   #5
why would there be water on the posts... shouldn't you address those as well?
KUIPORNG is offline   Reply With Quote
Old 10-02-2007, 12:20 PM   #6
These posts are sunk into the floor and down into the cocrete footing. These footings can get moist from the ground below and slowly rust the pole. There's not a whole lot you'll do since it will take many years to fail and it's not really worth the effort.
Opon replacement, you can seal the pole that's below the floor surface so it takes longer the next time.
Ron
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
replacing carport supports with 4x4 pt posts timmorin@clearchannel.com Carpentry 7 09-10-2007 01:19 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 07:32 PM
Deck Posts question flyultralite Building & Construction 1 06-23-2007 10:18 AM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
