Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-23-2008, 05:22 PM   #1
Post
Replacing Kitchen Countertops
Does anyone out there know if it is possible to replace tile countertops with laminate countertops for the kitchen? There are some nice ones at Home Depot that are in stock already, and quite budget-friendly. Is this a job for Superman, or should I get some help from my licensed carpenter friend? Does the tile need to be dug-out first? Let me know!! Thanks
diyDiva40 is offline   Reply With Quote
Old 09-23-2008, 09:44 PM   #2
Moderator
Termite's Avatar
The tile would need to be completely removed, as well as the tile's substrate. Typically those pre-made laminated countertops are intended to be installed directly onto the cabinet carcasses.
If you have a carpenter friend, I'd try to get his help. Especially if there are any corners that will require joining.
Old 09-25-2008, 09:30 PM   #3
depending on your existing walls and backsplash.. this could be an involved projet. The budget minded pre-formed CT you spotted at the big box store...might take a very big effort to replace what you have.
Can you post a pic or two?
Big Bob is offline   Reply With Quote
my kitchen reno - complete remodel (with concrete countertop) Knucklez Project Showcase 310 11-17-2011 06:59 AM
Information needed on replacing kitchen subfloor lyren1970 Flooring 2 07-17-2008 02:03 AM
Replacing faulty GFI in kitchen. Wires too short. ShawnMcCool Electrical 12 06-09-2008 09:41 PM
Replacing Kitchen Cabinet Door Hinges Eric_ht Carpentry 4 04-18-2008 08:42 AM
Replacing Dimmer for kitchen lights tmcguirk Electrical 2 04-16-2008 09:38 PM
