-   -   Replacing Hardwoods with Carpet (http://www.diychatroom.com/f15/replacing-hardwoods-carpet-53319/)
kemp 09-18-2009 04:24 PM
I will be removing some hardwood floors as part of a larger remodeling project. Underneath the hardwoods there is a layer of felt. Underneath the felt there is the sub-floor. This sub-floor is what I have a question about.
The existing sub-floor rest directly on top of the floor joists and is made from 1X6s angled at 45. Between each 1X6 there is a small gap -- about 1/8".
I want to put carpet down over this sub-floor.
My guess is that I need to lay down a thin sheet of 1/8" plywood -- over the existing felt -- before laying down padding and carpet.
So, my new sub-floor would be:
1X6s (existing)
felt (existing)
1/8 plywood
padding
carpet
Does that sound about right?
For those who can't help but ask -- I am using the hardwoods in another part of the house. ;)
bjbatlanta 09-18-2009 04:30 PM
You cannot buy 1/8" plywood. Thinnest I'm aware of is 1/4". You really need to use 1/2" though. The felt was installed to keep the hardwood from "rubbing" against the 1x's an causing squeaks. I don't see any harm in leaving it. Others more knowledgeable in this particular field may say otherwise.....
