Replacing Existing Exterior Door And Jamb - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 02:16 PM   #1
Replacing pre-hung exterior door- Gap ok on hinge side of jamb?
Hi - I'm replacing an existing exterior door with a pre-hung new door. The hinge side of the existing jamb is flush up against the rough opening stud, and there is about a 2 inch gap on the handle side of the existing jamb. My question is in regard to this: in replacing the door unit, I'd like ideally to center the new jamb in the rough opening, which would create about an inch gap on both sides, and then shim on both sides. The reason for this is for appearance, as it will look better centered. Will it be a problem for the entire hinge side of the door to be shimmed, as opposed to being flush against the stud?
Any thoughts on this are most appreciated. - Thanks!
oneaustin is offline   Reply With Quote
Old 04-12-2010, 06:06 PM   #2
kwikfishron's Avatar
Rewards Points: 90
Yes, but I would fir it in with double ” plywood instead of a big stack of shims.
kwikfishron is online now   Reply With Quote
Replacing NM in existing home Klawman Electrical 15 02-23-2010 03:48 PM
Replacing Roof with Certainteed.Replace existing Ridge Master ridge vent? JW Johnson Roofing/Siding 4 11-06-2009 09:59 AM
replacing existing light with can light? mferguson0414 Electrical 5 01-23-2009 08:45 AM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 07:00 PM
Replacing existing wall with support beam or I beam sourdough Building & Construction 4 08-06-2008 10:42 AM
