Replacing Double Window With Sliding Glass Door. - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 08:09 AM   #16
twalstrom's Avatar
Originally Posted by kwikfishron
So where does it say that anywhere?
Other than you bringing it up a few times I've never heard of or read that anywhere.
I actually read 3.25" recommend but not that it's code.
twalstrom is offline   Reply With Quote
Old 09-14-2012, 11:56 AM   #17
GBrackins's Avatar
Rewards Points: 2,108
kwik,
to my knowledge the only requirement in the 2009 International Residential Code for a drop in floor elevation from interior to exterior is:
R311.3.1 Floor elevations at the required egress doors. Landings or floors at the required egress door shall not be more than 1-1/2 inches (38 mm) lower than the top of the threshold.
Exception:
The exterior landing or floor shall not be more than 73/4 inches (196 mm) below the top of the threshold provided the door does not swing over the landing or floor.
The 4" comes from the International Building Code, which can be used (and sometimes required) in the design of residential structures.
1009.4.2 Riser height and tread depth. Stair riser heights shall be 7 inches (178 mm) maximum and 4 inches (102 mm) minimum.
Anything less than 4" (even 4" can be) become a trip hazard.
Hope that helps!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-15-2012, 06:29 AM   #18
kwikfishron's Avatar
Rewards Points: 798
Originally Posted by GBrackins View Post
kwik,
Exception:
Hope that helps!
Thanks, I knew that. What I was referring too was a requirement that said the deck surface "must" be at a lower elevation than the floor inside, which is what I thought Joe was referring too.
Although a good idea for weatherproofing I don’t think it’s required, in fact in the case of multi-unit dwellings and public places it’s not allowed (as a step anyway).
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
GBrackins (09-16-2012)
Old 09-16-2012, 12:25 AM   #19
GBrackins's Avatar
I figured that you knew by asking the question .....
I gave the only IRC code section I am aware that gives the requirements for interior and exterior floor levels and as can be seen, there is no requirement for an exterior landing/deck/floor to be lower than the inside, in fact it limits the maximum drop as 1-1/2" lower than the top of the threshold unless a door does not swing over it (going outward).
As you state for weatherproofing it is an excellent idea to drop the deck lower than the inside.
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
kwikfishron (09-16-2012)
Old 09-16-2012, 09:53 AM   #20
AHH, SPANS!!!
Rewards Points: 1,166
one thing you will want to do is make sure there is not a support 2x4 between the windows , known as a stud pocket. chances are you have a full header above but maybe not. the best way to find out is to demo drywall and expose framing and pull the mullion trim between the windows to see inside of the slotted space...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
twalstrom (09-17-2012)
Old 09-17-2012, 06:23 PM   #21
twalstrom's Avatar
Thanks guys. The deck is totally finished now (pics to come). I will be looking to tackle the door within a week or so.
Replacing double window with sliding glass door.-image-1269966673.jpg   Replacing double window with sliding glass door.-image-2580679567.jpg
Old 09-18-2012, 12:26 PM   #22
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Is it a free standing deck?
CoconutPete is offline   Reply With Quote
Old 09-18-2012, 04:18 PM   #23
twalstrom's Avatar
Yes it is.....
Old 09-19-2012, 08:12 AM   #24
Rewards Points: 504
Do you have any pics of the inside?
How wide is that window?
I would remove some trim and drywall from the inside, it's what I ended up doing that finally gave me the confidene to just tear into it. I was looking at a single width door which if my memory serves me correctly was 82" in height, but the header I found was 80" above the subfloor so I ended up with a slider that was 80" in height so it worked out perfectly since I gained 1/2" by going down to the subfloor.
If you remove the drywall you will be able to see exactly what kind of a door you can fit in there.
Is that vinyl siding or clapboard?
Old 09-20-2012, 10:53 AM   #25
PLEASE PLEASE post pictures of your progress with the door, I have this exact same project coming up!
rebelranger is offline   Reply With Quote
Old 09-20-2012, 10:59 AM   #26
twalstrom's Avatar
Will do, it will be at least a few weeks before I start.
Old 09-22-2012, 09:40 AM   #27
twalstrom's Avatar
Okay, window jam total width is 75". Height is 80". Sorry for the dark pic.....
If I go with a door this size it will be perfect...... http://www.lowes.com/pd_391799-94705...etInfo=Sliding
Old 09-22-2012, 09:41 AM   #28
twalstrom's Avatar
Here is the pic....
Old 09-24-2012, 08:21 AM   #29
Rewards Points: 504
That's the same size door I put in my house, I don't know anything about that door though, I used an Andersen door.
You're going to have to re-route that electric - do you have a basement or a crawlspace? I had to do the same, it came in handy to have the wife upstairs while i was crawling around down there. I had to move a duct too though, looks like you're a bit luckier than I am.
Pull the curtains, pull the window trim and cut the drywall from the window edge and straight down and pull it. Do the same above the window, pull out whatever insulation might be there, that should give you a good idea of what you're working with.
Old 09-24-2012, 09:39 AM   #30
twalstrom's Avatar
I do have a basement. Rerouting the electric will be easy as I have done it for my kitchen renovation already. I will most likely re-route it to be an outdoor outlet for the deck and connect a switch/ outdoor light.
Unfortunately it got cold here real quick. It's 36 here. Yikes!!!! Hopefully a bit of a warmer weekend is in my future to get this done. I'll keep everyone posted.
New weatherstrip for sliding glass door info2x Windows and Doors 13 10-08-2016 10:19 PM
Replacing window glass Donald-64 Windows and Doors 3 04-23-2012 11:09 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 05:01 AM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
