Replacing Double Window With Sliding Glass Door. - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 11:15 PM   #1
twalstrom's Avatar
Replacing double window with sliding glass door.
Hey Guys,
This is my first time posting so hello to you all!!!
What I am doing is very similar to this thread...... Putting a door where this window is .....
I would like to confirm that as long as there is a header going across the entire wall I can simply install my sliding glass doors using the existing window frame.
twalstrom is offline   Reply With Quote
Old 09-13-2012, 11:26 PM   #2
Rewards Points: 2,210
as long as the header is high enough and wide enough (can be higher and wider and just fill in) you're good to go.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
twalstrom (09-13-2012)
Old 09-13-2012, 11:27 PM   #3
Rewards Points: 13,300
#1 You have to know what the rough opening of the door your planing on installing is before doing anything. If it's the same or smaller then the R/O of the windows it can be done without to much distruction.
If it's bigger then it's a lot more work because your going to be dealling having to install a longer header.
#2 That doors threshold has to be at least 4" above the finished surface of the deck.
Old 09-13-2012, 11:28 PM   #4
twalstrom's Avatar
Great, I will be posting pics of the process!! Thanks for the reply!!
Old 09-13-2012, 11:29 PM   #5
twalstrom's Avatar
#2 That doors threshold has to be at least 4" below the finished surface of the deck.
Huh, that I did not know. What is the reasoning behind the 4"?
Old 09-13-2012, 11:33 PM   #6
It would have been a whole lot easer to have installed the door before building the deck.
There needs to be support installed under the threshold on the outside wall as well as flashing to protect the wall, Not sure how your going to do that with the deck in the way.
Old 09-13-2012, 11:34 PM   #7
Busy DIYer
picflight's Avatar
Rewards Points: 150
4" below or above?
Sent from my iPhone using DIY Forum
picflight is offline   Reply With Quote
Old 09-13-2012, 11:41 PM   #8
twalstrom's Avatar
Also, what type of support does the threshold need? Is there a diagram or resource you could recommend?
Thanks!
Old 09-13-2012, 11:56 PM   #9
Opps my fault for the typo. The doors threshold needs to be 4" or more above the decks surface.
#1 That's code.
#2 That's to prevent water from getting in under the threshold.
If you take the time to look look around long enough on this site or any DIY site you will find hundreds of people dealing with floor, wall, foundation, sheetrock damage from this one common mistake.
I also always install any french door or sliding door so it sits in a sill pan. That way when the door leaks (and most do at some point) the water is directed outside not inside.
Just do a key word search on Jam Sill to see what one looks like.
The aluminum sill on a door sticks out behind the sheathing about 1-1/2". If it's not supported it will twist when steped on, which will cause nothing but trouble with the rollers, and the caulking to crack in the outside corners.
I use a piece of 1 X 6 vinyl lumber with stainless steel trim head screws to support it. No painting, no rotting, fully supported.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (09-14-2012), twalstrom (09-14-2012)
Old 09-14-2012, 12:19 AM   #10
Fully agree with the support for the sill, I like to do this on all exterior doors.
Old 09-14-2012, 12:25 AM   #11
http://jamsill.com/
I've made a ton of money going back and having to fix sliders, french doors, even reguler doors that were not supported correctly.
Time and time again builders will use something like a pressure treated 2 X 4 or 6.
A 2X sticks out to far and will do nothing but make a funnel for water to get in. It also looks like poop.
Old 09-14-2012, 12:29 AM   #12
twalstrom's Avatar
I feel like I will have no problem doing that with the deck already there as it is at least 2" lower than my floor..
Old 09-14-2012, 01:36 AM   #13
hard to slip in the 1x6 or even 1x4 support
Old 09-14-2012, 01:39 AM   #14
Or the water proofing behind it to protect the sheathing.
Old 09-14-2012, 07:18 AM   #15
kwikfishron's Avatar
Rewards Points: 210
#1 That's code.
So where does it say that anywhere?
Other than you bringing it up a few times I've never heard of or read that anywhere.
kwikfishron is online now   Reply With Quote
New weatherstrip for sliding glass door info2x Windows and Doors 13 10-08-2016 11:19 PM
Replacing window glass Donald-64 Windows and Doors 3 04-24-2012 12:09 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 10:07 PM
