Replacing Door On Brick Wall. Missing Lintel! Advice? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 05:51 PM   #1
Rewards Points: 28
Replacing door on brick wall. Missing lintel! Advice?
Hi, I am replacing the an intererior door between house and breeezeway/garage with 30" firedoor. Breezeway side or wall is brick. Rough opeinging of brick is 33 1/2" W. After removing moulding around existing crappy door, I found no lintel in brick. It's been like this for 35+ years with no problems, bricks are in place and look solid but its time to fix all the mistakes and do it right.
Any tips on adding a lintel while doing minimal brick work??
Since the bricks and mortar look to be in good shape with no cracks, the easiest thing seems to be a flat bar across the span extending past the sides. This way I would just need to remove some motar. Is there such a thing as a flat bar lintel?
wad2k is offline   Reply With Quote
Old 04-25-2010, 06:27 PM   #2
you could turn a metal lintel upside down and rip/torch the hanging edge to clear the door jamb then rabbit the back of the head casing to fit
The older I get the better I was
Old 04-25-2010, 06:38 PM   #3
Concrete & Masonry
Rewards Points: 548
How old is the house? Sounds like it may be a "jack arch" that's doing exactly what it was intended to. Pics are worth 1000 words.
jomama45 is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Replacing band joist behind brick veneer jzambon Building & Construction 0 03-09-2010 11:58 AM
Replacing Landscaping Tie Retaining Wall omnic Landscaping & Lawn Care 1 05-01-2009 05:14 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
