Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-19-2008, 01:58 PM   #1
Replacing aluminum frame windows
I've ordered some vinyl replacement windows for the addition at my house. I've already replaced several in my home that were old wooden frame windows and it went relatively painlessly. Used the old outer window stops, didn't have to do any flashing work on the outside. The windows in my addition, however, are single-pane aluminum frame windows. They almost look like windows you'd find on a trailer. Anyhow, my problem is that unlike the wooden windows that I replaced, there are no outer window stops around the window frame. The outsides of the aluminum windows have a lip (about 1.5") that overlaps the frame, and screws were put through this lip to attach the windows. I'm just wondering if I can tack on some window stops on the outer frame, and what types of materials I shoudl use to finish the outsides of the window. A quick tutorial on doing flashing may be in order if I have to put in new flashing as I've never installed it before. Any suggestions are appreciated!
gallasm is offline   Reply With Quote
Old 12-19-2008, 08:50 PM   #2
Licensed Eng/Contractor
Aggie67's Avatar
Can you post a photo?
Aggie67 is offline   Reply With Quote
Old 01-05-2009, 11:03 AM   #3
Well, here's a pic I had laying around. It's not a great one, but you can at least see the type of window I'm dealing with. The more I read up on this, the more I'm thinking I should have ordered new construction windows instead of replacement windows. Is this do-able with replacement windows? Because Lowe's just called me and said my windows arrived... Guess I don't want to just start tearing out the old windows only to find out that the replacement ones won't work.
Tags
replacement windows
More On This Topic
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Sometimes the plastic window panels decorating a wooden garage door become warped, discolored, cracked or broken. With a little elbow grease and patience, you can pry up the wooden frame around the offending window and replace the plastic with a new... Read More »
Restoring a classic wooden power boat is a labor of love. The classic, sleek form of an old wooden power boat is irresistible. Restoring the power boat's wooden body and old engine is expensive, but the value of a classic wooden power boat far outweighs... Read More »
How to Install New Windows
How to Install New Windows by Expert Village
Hi I am David Belch and I here with Expert Village today to show you how to install windows. What I am going to do now is place the window in the opening. This is the right replacement. Since I have a top stop I just want to hold my window in, it is a... Read More »
Unlike a motion tween, which moves or rotates an object across a space, a shape tween allows you to actually morph one object into another. Once you define both shapes, Flash will do the rest--changing form and color according to your instructions. Read More »
Replace Aluminum Windows lpcon Building & Construction 2 09-28-2008 08:48 PM
installing full frame windows with existing siding mlmaher Building & Construction 3 09-11-2008 08:56 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
