Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-19-2009, 08:51 PM   #1
Default Replacing a 6x6 post with a laminated wood beam
I have a 6x6 wood support post, just at the bottom of my stairs in my basement. I want to pull that out, and put a support beam from the barring wall on the left side of the stairs, over to the wall for the basement bedroom. the span is just over 7 feet. How big of a wood beam do I need? I have the space to put in a 6 inch wide laminated beam, that could be as thick as 12 to 14 inches. will that work??
wazzie is offline   Reply With Quote
Old 03-19-2009, 09:04 PM   #2
Five Star's Avatar
Beam and post are 2 different things.
before you take anything out, what exactly are you trying to accomplish..?
any pics..?
Five Star is offline   Reply With Quote
Old 03-19-2009, 11:01 PM   #3
You can't just pull out a vertical support and slap up some off the cuff theoretical remedy based on, "what you can fit". It needs to be calculated by someone qualified who actually visits your house.
Try calling an engineer or architect.
You can't rely on clowns on the internet, It's like asking a monkey with a stick beating on a termite mound. No good will come of it.
Ron
Old 03-21-2009, 12:18 PM   #4
knowsomethings
Seriously, take Ron6519's advice. You need an engineer.
Greg
runout is offline   Reply With Quote
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
How to Use a Quick Square
How to Use a Quick Square by Expert Village
Hi! I'm Drew Finn here for Expert Village. We are going to talk about standard hand tools and how to use them. This is a quick square and it is used for framing. I find it very handy around the house just to do quick little jobs. It's got a lip on here... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
wood fence post farrington135 Building & Construction 10 06-28-2009 10:38 AM
post and beam subfloor mattchapp Flooring 0 02-08-2009 02:09 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 5 07-07-2008 10:33 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 01:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
