Replacing 12" Ceiling Tile With Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-08-2007, 10:21 PM   #1
Replacing 12" ceiling tile with drywall
Hello all! I'm looking for some suggestions on my latest project. I'm working on a 24' X 11' living room that used to have a 12" tile ceiling stapled to furring strips over some very old 1/2 drywall. My first plan was to rip everything down and hang drywall to the 2X4 ceiling joists which are spaced at 2'. However now I'm looking for another option the wouldn't result in a living room full all the insulation and other stuff that lies above that old drywall...
Can I just fasten new drywall to the furring strips without problems if they are fastened securely? Everything seems fairly level, but I could shim as needed.
Would two layers of 1/2" drywall be too much weight for 2X4 ceiling joists?
housefixin is offline   Reply With Quote
Old 09-08-2007, 11:54 PM   #2
Rewards Points: 150
That stuff is nasty and I took it down in my rec room which was a 12 x 20 space... put up dry wall in its place... it was a bit messy, but all in all, it really was only a 2 day job. I think it's worth it to get a clean start instead of hangning more drywall on drywall....
slakker is offline   Reply With Quote
Old 09-09-2007, 10:10 AM   #3
Rewards Points: 5,336
I don"t know how a space that size could be spanned with 2x4's. At 11 feet I would expect 2x8's at a minimum. I would want to know how these framing members were installed and braced. It sound like these are trusses. Two feet apart and 2x4's. Are these trusses?
To minimize the added weight you can use 3/8" sheetrock over the furring strips. If you were going directly to the old sheetrock, I would use 1/4", glued and screwed.
Ron
Old 09-09-2007, 10:36 AM   #4
Mod / ArchiBuilder
Cole's Avatar
I am confused as well.
Any pictures?
Cole is offline   Reply With Quote
Old 09-09-2007, 12:10 PM   #5
Thanks for all the replies!
The house is a 90 year old bungalow, and the original structure in only 24' X 24' with a load bearing wall off center down the middle. There are 1X4's and 1X6's on top of the 2X4 ceiling joists and insulation is sandwiched between the old drywall and the 1X's, as well as loose insulation above them. So there are no trusses, just rafters.
Even If I did rip the whole ceiling down and start over, I would probably run some sort of stiffeners or furring strips to help distribute the load better and prevent ceiling cracks. Being very short on free time though, I would probably re-install new ceiling tile before tearing into the old drywall and insulation... I would prefer drywall because the tile can look kinda cheesy, but I also don't want to hang drywall on the furring strips and end up with a sagging and cracked ceiling.
What do you guys think? with this kind of set up, and lots of screws in the furring strips and 3/8 or 1/2 drywall, would this hold up??
I'll try to get some pics later.
Old 09-09-2007, 03:00 PM   #6
Mod / ArchiBuilder
Cole's Avatar
I understand now, yes you should be ok going with new drywall on the furring strips that are on the joists. Make sure the furring strips have plenty of good solid screws in them.
Ceramic Tile on Drywall fisher501 Flooring 3 03-20-2011 04:48 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
