Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-08-2007, 10:40 AM   #1
Replacement Windows-Storm Windows
I am looking to replace the windows in my 1968 ranch home in Wisconsin.
I have already had a salesman in my house selling some very expensive vinyl windows.
I have decided to do it myself as it will save me a ton of money.
The question I have is that while I am confident that I can easily install new pocket replacement windows, I currently have aluminum storm windows that are installed on the outside of the house. What do I do with them? Should I leave them installed or remove them?
If I remove them it looks like I will need to re-install the exterior trim around the windows. The exterior of the house is vinyl siding.
Is there any disadvantage to leaving the storm windows installed?
simon is offline   Reply With Quote
Old 10-08-2007, 12:01 PM   #2
can you post a photo of the windows from the exterior view?
redline is offline   Reply With Quote
Old 10-08-2007, 02:49 PM   #3
I had the same thing on my windows, but my storm windows were not attached to the trim, they were attached to the outer edge of the window. I had my replacements with Argon and Low E so the need for extra insulation with a storm window wasn't needed. The only down side to keeping the storms is that it would be difficult to do any work from the outside. You might be able to take them off and put them back on. A picture would help.
cibula11 is offline   Reply With Quote
Old 10-08-2007, 06:21 PM   #4
GMW
It is pefectly fine to leave them on, however some vinyl replacement windows have a screen channel that sticks out to far and the storm will interfere and not let the window seat properly. If you do take the storms off, it might not look great if the windows were wrapped with aluminum with the storms in place. You will have bare wood and a rough aluminum edge. Fixing the aluminum wrap is hard for the homeowner, needs special tools and skills. Each application is different, they are easy to do if you know what you are geting into. Good luck. Please post back, Most people never post again to let us know how it came out.
GMW is offline   Reply With Quote
Old 10-09-2007, 02:34 AM   #5
I had the same situation on my house. The storms were attached to the outer window stops.If you buy quality windows you will not need the storms any longer.I could'nt wait to take mine off,what an improvement in looks.All you need is to trim the stops were the storm was attached.Talk to a siding contractor.This is small busy work for them and it should'nt cost much at all for them to trim the stops for you,or even retrim the entire window.
white29 is offline   Reply With Quote
Old 10-09-2007, 09:52 AM   #6
Here are some pictures of the exterior of the windows.
replacement-windows-storm-windows-exteriorwindow1.jpg   replacement-windows-storm-windows-exteriorwindow2.jpg   replacement-windows-storm-windows-exteriorwindow3.jpg
Old 10-09-2007, 05:14 PM   #7
If the storms are in good shape, leave them. When you install the new windows, remove the screens.
Old 10-15-2007, 08:07 AM   #8
[quote=Rahim;68137]I work for a nationwide company that installs energy efficient windows for a low price. If you want good quality windows at a low price go to the bottom link. This special link will enable you to get a free estimate. That way you can compare prices with different competitors and find whats best for you.
Spam
Old 10-22-2007, 10:17 PM   #9
PRO Siding Windows Roofs
You would never want to leave your storms on over a vinyl window for several reasons. First of all they look horrible and are probably so dirty that you cant see through them, in addition they generally are awkward to open and close. More importantly the heat build up that can be created between the storm window and your vinyl window can be hot enough to cause your vinyl window to distort and may even void your warranty. Finally any thermal value provided by the storm does next to nothing to improve the value of your vinyl window. I would remove the storms and have the trim re-wrapped. We charge on average $75 per window to re-wrap it with aluminum. From the pictures that your provided, The siders did a horrible job wrapping the trim as can be seen by the caulking globbed everywhere. A properly wrapped window will be done in such a way that caulking is not needed, and there are no gaps between pieces.
PKHI is offline   Reply With Quote
Old 10-23-2007, 09:44 PM   #10
fhi vinyl windows
fhivinylwindows's Avatar
Good Post!
To the OP, if you end up installing the windows on your own hire someone for the metal work. The labor rates vary, some people will do it for $25 and some for $100. I would suggest hiring someone that will spend a little time getting you started on your first window. If they are not installed properly you are just wasting you money.
fhivinylwindows is offline   Reply With Quote
Old 10-25-2007, 06:47 PM   #11
I Could'nt agree more with the last two posts.Learn to properly install the new windows,attention to detail counts in squaring and shimming the openings and then insulating the space before retrimming the interior.By all means,especially after viewing your pics,get rid of those God awful storms so your nice looking new windows can be seen after you have the exterior trim rewrapped by a competent siding pro. And IMO windows with grills built in lok especially cool. Good luck.
Old 10-29-2007, 11:59 AM   #12
Just an update, I have ordered all new replacement windows from Home Depot, I went with the American Craftsman 9500 series windows with integrated grilles.
The storms are definitely coming off and I am going to look for a siding pro to trim out the windows while I wait for my new windows to arrive.
Thanks for all the advice!
Old 10-29-2007, 06:26 PM   #13
We replace a lot of American craftsman windows once the spiral balances rust stuck and the windows don't open or don't stay up. Not to mention they are a really ugly looking window
Old 10-29-2007, 07:12 PM   #14
Remodeling Contractor
oldfrt's Avatar
In my opinion ,anything from Home Depot is JUNK!.
They charge pretty much the same as anyone else on their supplies,but it is a lower grade.This always goes unnoticed by home owners because they don't know what to look for.They think they are getting a deal,but the quality will come back and bite you in the azz.
I've been in business for 30 years and feel I have a good finger on what quality and what's junk.
Spiral balances have always been a problem with any replacement window.The companies that still use this feature are living in the dark ages.
It seems easy to just stop by your local HD,but I've been called to replace this type of window within 10 years of installation.
Try and find a contractor that will order the windows for you .Tell him you want to install them.Do this before he comes to measure them ,because he may not offer a warranty unless he installs them.It may be a little more money,but it will be worth it.
oldfrt is offline   Reply With Quote
Old 11-02-2007, 09:42 PM   #15
Actually I have to disagree with you on the HD thing. I worked for a large window and door manufacturer and I can tell you that the stuff that you buy at HD is the same quality as an independant dealer. They just make the product more option fraindly for the independants. Now working as a contractor I can also say that I do not like the HD's, but I find that the customer that insists on shopping at an HD center is not one that I would want to deal with in the first place.
Amber is offline   Reply With Quote
More On This Topic
Prepping the Sail Window
Prepping the Sail Window by Expert Village
In this clip, we're going to show how to install a window in the sail. So, during the layout process, we put the marks on the panel where the window's going to go. And we're going to use a twenty gauge clear vinyl for the window. So, I'm just going to... Read More »
Storm windows are a great way to help keep heat in your home during the winter months. These thick windows also help reduce outside noise and keep moisture out of your home. Fall is a great time to install storm windows because it's usually not quite... Read More »
There are many areas in the average home that are subject to drafts and air leaks. Whether it's dropped ceilings and window frames or air ducts or furnace flutes, chilly homes in the winter are unfortunately the norm. Air infiltrates into and out of your... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be caulking our seams. Now that I have my new trim board on I need to go back and put caulking in all of the seams as well as all my metal. This is really going to help prevent any... Read More »
Replacing your windows is one way to boost the value of your home, especially if the new windows are more energy efficient. One of the popular styles of replacement windows is vinyl retrofit replacement windows. Read this eHow to learn how to trim... Read More »
replacement windows in stucco houser Building & Construction 3 08-23-2007 12:28 AM
Opinion on HD American Craftsman replacement windows Jims69 Remodeling 2 10-26-2006 04:02 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
