Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-25-2008, 04:51 PM   #1
abc
replacement of plaster board
I've removed a portion of a plaster/plaster board wall to repair the sill plate and exterior wall, redo the electrical and reinsulate. The old wall was about 7/8 to 1" thick. When replacing the wall with sheetrock, should i use two pieces of 1/2" board, or should i try to use 3/8 or 1/2" furring strips and one piece of sheetrock? Where do I get 3/8 or 1/2" furring strips (i suppose that I can cut them from plywood or a 2x6)? Thoughts?
abc is offline   Reply With Quote
Old 03-25-2008, 09:09 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You "could" purchase 3/8" or 1/2" Furing strips from a Big Home Improvement Store, however, I would suggest just cutting them out of plywood, as it will not split, the way such purchased material will.
- Build Well -
Old 03-28-2008, 03:56 PM   #3
Use the old plaster lathes. Plaster was usually about a 1/2" thick variable,,but close enough. IF you have trim to replace its easier to get the wall out to that first rather than later!!
justdon is offline   Reply With Quote
York gas heater control board replacement spyvan HVAC 5 12-29-2008 08:12 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
Plaster replacement lburele Building & Construction 1 04-29-2007 10:48 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
