Replace Wood Railing Balusters - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-31-2009, 04:35 PM   #1
jad
replace wood railing balusters
Has anyone tried to replace the typical wooded stair balusters with new iorn ones?
Is the hand rail difficult to remove and use over? how about the hole in the steps, will a wrought iron be to small...etc etc..
lots of questions?
Thanks in advance
jad is offline   Reply With Quote
Old 03-31-2009, 08:47 PM   #2
Rewards Points: 5,326
While it is a possibility you can reuse the handrail, it all depends on the type of iron balusters you use and the current code for spacing.
Ron
Old 04-01-2009, 12:24 PM   #3
You will have to take measurements on the balluster top and bottom holes. Are the balluster tops square ended or pins? Is a shoe rail used on the bottom. How are the ballusters connected? Nails&glue?....dowels? The railing is always removable. How easy will depend on how it was installed. Have you picked out the new ballusters?
Maybe you should post a few pictures
beerdog is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Need help with caulking problem and fuzzy wood! Beth777 Painting 4 07-04-2008 04:06 AM
