Replace Vapor Barrier From Inside? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 01:26 AM   #1
replace vapor barrier from inside?
hey guys
first time homebuyer bought a quad level house and its tuning into quite the money pit
the leve that is 1/2 under ground has concrete slab wall on the bottom hall supporting standard wood frame above. outside is 1/2 brick venner below and aluminum siding above. problem is i ripped out the drywall and behind i found a colony of ants the are getting in through a hole in the brick mortar. i removed the fiber glass insulation and the water damaged silverclad cardboard vapor barrier, but now i want to reinstall the vapor barrior / insulation and im unsure how to proceede. cant do plastic beacause there are brick wall anchors nailed to the wood frame. how should i proceede? friend suggest spray in foam insulation, hes not sure on its water / water vapor / inscect resistant capabilities? anyone care to comment? thanks ps im ready to go back to an apartment! please help!
gopher
gopher is offline   Reply With Quote
Old 09-14-2009, 12:39 PM   #2
spray foam may be a good solution. Closed cell spray foam is a class 2 vapor retarder, open cell foam, I believe is class 3 (the pros may correct me on this). You will want to maintain the drain-space between the brick veneer and the sheathing.
rizzo is offline   Reply With Quote
Old 09-14-2009, 01:25 PM   #3
so your saying not to spray the foam against the brick wall?
Old 09-15-2009, 11:56 PM   #4
ok i made a pic maybe it will wake up this thread
i need to know how to replace that vapor barrier and what i should use to seal in the ant tunnels?
Replace Aluminum Windows lpcon Building & Construction 6 12-21-2013 03:01 PM
Replace old thermostat with new electronic one hermhart HVAC 3 10-07-2009 08:08 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
