Replace Post Anchor - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2007, 07:01 PM   #1
Replace post anchor
I have a deck post with a rusted post anchor. Is there a product out there that I can add on to replace the anchor without replacing the post. The post in not rotten in any way. Or is there a brace/anchor brace I can add?
reneebri90 is offline   Reply With Quote
Old 11-26-2007, 12:52 PM   #2
Rewards Points: 5,336
Most are easily replaced. What you chose would depend on the setup you have. Post a picture.
Ron
Old 12-01-2007, 10:07 PM   #3
Size:  15.6 KBName:  IMAG0049_edited.JPG
Here is the picture. I think. I had a hard time figuring this out.
Old 12-01-2007, 10:46 PM   #4
You can use one of the Simpson brackets. Just go to a local lumber yard or one of the Borgs. This bracket is bolted to the ground. You'll need to remove the old bracket while supporting the structure above. The nut might come off and the threaded section might be useful. If not you'll need to remove the rod and insert another device. Look through a few deck books for the details. If any of this is uncertain, hire someone, you could hurt yourself.
Ron
Old 12-08-2007, 11:56 PM   #5
Mod / ArchiBuilder
Cole's Avatar
This post is pretty old, but I gave you some sketches of what you should do to remove the post and replace the anchor.
Cole is offline   Reply With Quote
Old 12-08-2007, 11:56 PM   #6
Mod / ArchiBuilder
Cole's Avatar
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 03:20 PM
replace porch post? lrciii Building & Construction 3 07-16-2007 10:12 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
