Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-08-2010, 11:20 PM   #1
analogmusicman's Avatar
replace interior window sills
all my windows have these sills made out of some synthetic material kind of like what the newer sinks are made of and I'd like to replace 'em. can't see how they're attached,could they be glued in? can I just pry them out? is gluing an acceptable thing when it comes to sills?
tnx,
analogmusicman is offline   Reply With Quote
Old 07-09-2010, 06:23 AM   #2
Super Moderator
Are you talking about interior sills? If so they are probably just glued in. Try a painters tool as a wedge
and see if you can pop them loose.
Post a picture---Mike--
oh'mike is online now   Reply With Quote
Old 07-09-2010, 08:55 AM   #3
Household Handyman
The composite sill could be attached to the window framing with staples from the bottom of the sill into the framing. IF this is composite material why are you wanting to replace it/them? You can get new sills in both wood and/or a PVC material for replacement. When replacing damaged/rotted sills I usually cut the old sill out about 3-4 inches from each end, then work a thin Saw-Zall blade under the window framing and the old sill piece to cut the staples. Or, I just use the old "beat-it-out" method if I have to. Good Luck, David
Old 07-10-2010, 02:12 PM   #4
tnx,
Take a photo of the sill. If you know the window manufacturer, post it. You shouldn't pull anything apart unless you know everything about it's construction.
Ron
BIG PROBLEMS with cabin mud sills and floor scylla2 Building & Construction 1 10-18-2009 09:34 PM
PVC window sills thegal59 Carpentry 9 09-20-2009 09:25 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Replacing Brick Window Sills gmac111 Building & Construction 3 06-12-2009 10:54 AM
Attaching Limestone Sills to Wood Framing BigJimmy Carpentry 8 11-14-2008 10:11 PM
