Replace Floor Joist - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 07:51 AM   #1
Replace floor joist
How do I replace floor joist that are mortised into a brick masonry wall? The building was buit in the 1800s. The existing joist are a true 2"x12" and I want to replace them with a nominal 2x12.
654321 is offline   Reply With Quote
Old 03-27-2012, 08:11 AM   #2
Civil Engineer
Rewards Points: 4,940
Simplest way is to remove the existing joist by cutting it out, providing adequate temporary support to the floor above. Install a new joist using metal support brackets appropriately anchored to the brick. This may require epoxy anchors, lead shields, or similar anchor devices, and assumes the brick is structural and in good condition.
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
