Replace Bathroom Trim - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 07:32 PM   #1
bryanp22's Avatar
Rewards Points: 294
Replace bathroom trim
We are replacing a pedestal sink because of a leak and I have to repair the wall some since the prior owner decided to use adhesive caulk to adhere the sink basin to the wall instead of using screws with a board behind the wall. My fiancÚ asked if we could replace the tile trim along the floor too while we are doing a mini remodel. I've attached a picture. How hard is it to remove the tile? Can I replace it with standard wood baseboard? We have standard wood moulding around the doors and windows already, but wanted to double check. Any recommendations for technique on removing the tile to not damage the floor. I don't mind minor repairs to the plaster I already have to fix the sink area.
bryanp22 is offline   Reply With Quote
Old 02-19-2012, 07:33 PM   #2
bryanp22's Avatar
Rewards Points: 294
Forgot to attach picture
Old 02-20-2012, 09:52 AM   #3
DeeKayVB's Avatar
I recently removed some tiles from a wall and it just depends ... some came off easily and some were more stubborn. If you are careful, most wall damage can be patched wt compound. I think baseboard would be a great idea since the tiles do not match well.
DeeKayVB is offline   Reply With Quote
Old 02-20-2012, 10:58 AM   #4
Rewards Points: 13,752
A sharp blow from the top of the tile with a brick chisle and a hammer should pop it off.
Old 02-20-2012, 10:58 AM   #5
bryanp22's Avatar
Rewards Points: 294
Any recommended technique? I've never removed tile before where I had to minimize wall damage
Old 02-20-2012, 11:00 AM   #6
bryanp22's Avatar
Rewards Points: 294
Okay, I'll picked a brick chisel.
Old 02-20-2012, 04:21 PM   #7
Rewards Points: 512
i'd use a flat pry bar and put it between the tile and the wall and whack with a hammer and they should just pop off. then pick out a baseboard that was taller then the tile and no drywall repairs.... if you dont accidently hit the wall while removing the tile lol
princelake is offline   Reply With Quote
Old 02-20-2012, 07:35 PM   #8
bryanp22's Avatar
Rewards Points: 294
The masonry chisel is working well. I don't think they used thinset though. It was either used very sparingly or it's construction adhesive.
Old 02-23-2012, 08:35 AM   #9
This method worked perfect for me as well.
Measure from the floor to the top of the ragged edge that will probably be on the drywall after the tiles are removed. Buy some moulding the same size or a bit taller (4 1/4 worked for me) and some base shoe or quarter round.
Put a wood shim on the floor (thick end against the wall with moulding on top of it) nail and glue your molding to the wall, install shoe/quarter to cover gap at bottom.
Doorman54 is offline   Reply With Quote
Old 02-23-2012, 08:46 AM   #10
bryanp22's Avatar
Rewards Points: 294
Yeah I have colonial 3 1/4 moulding throughout the house which perfect height once top edge is caulked
Old 02-23-2012, 10:00 AM   #11
Missouri Bound's Avatar
Take a razor knife and run it along the top of the tile before you try to remove it...that will minimize tearing when you pry the tile loose. Start with a stiff putty knife to pry. The thinner the prying object the less chance of breaking the tile.
Do you want it your way or the right way?
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 02:17 PM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
