Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-17-2010, 01:05 PM   #1
Question
replace 2x6 jams around garage
I want to replace the 3 pieces of 2x6 jams around my garage. The 2 side pieces look easy to pull out but I'm wondering about the top 2x6 jam attached to the bottom header. Is that ok to replace with concerns of the header coming down? The jams are rotted..
TIA,
Tom
Tom241953 is offline   Reply With Quote
Old 06-17-2010, 01:13 PM   #2
Handyman
Yes, its ok to remove that but you may want to use a reciprocating saw with a metal blade to cut through the nails...lots easier than prying.
canadaclub is offline   Reply With Quote
Old 06-21-2010, 06:38 AM   #3
Thanks canadaclub.. Jams came out easily using the reciprocating saw..
Old 06-21-2010, 10:26 PM   #4
Moderator
Don't forget to replace the head flashing, if rusted through....
Be safe, Gary
Clothes taking longer to dry?
Old 06-22-2010, 06:35 AM   #5
thanks Gary for pointing that out. head flashing was in good shape. no rust.
Have a great day.
Tom
Tags
garage door jams, jams, rotted jams
Attached Garage, No sub panel, seperate grounding rod danocars Electrical 6 03-15-2010 06:27 PM
How To Replace an Old Garage door Lock system apetrag How To Guides 4 12-17-2009 07:31 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Replace Missing Garage Rafters Parrotheadrik Building & Construction 4 05-02-2008 08:29 AM
