Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-05-2008, 02:49 PM   #1
Question
Repair Fixture Hole in Ceiling
I want to replace my 5" light fixture and put in a smaller 3" recess light -- is there a way to repair the hole in a ceiling that the 5" fixture will leave? I know how to do this with dry wall, but my ceiling is made of a much thicker "sheet roock type" material... what is it and how to I repair a hole?
lost80s is offline   Reply With Quote
Old 02-05-2008, 05:22 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Can you post any pics of your thick ceiling material?
Cole is offline   Reply With Quote
Old 02-05-2008, 07:09 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's repaired with Drywall tape and compound. Basically, you have to slowly fill in the hole. After several coats and sanding, you draw out the hole size desired, then score the line with a utility knife.
Last, cut out the shape with your utility knife or router.
- Build Well -
Old 02-08-2008, 01:42 PM   #4
ok thanks - do you have idea what material ceilings are made of tho? It is much thicker than dry wall (like double the thickness) - but I can tell the material is the same.
Old 02-09-2008, 06:39 AM   #5
Remodeling Contractor
wolffhomerepair's Avatar
Sounds like plaster and plaster board. Usually about 3/4" thick. I just patched some of this last week. Atlantic is correct. Same technique as drywall.
wolffhomerepair is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 04:55 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
