-   -   Repair Fixture Hole in Ceiling (http://www.diychatroom.com/f15/repair-fixture-hole-ceiling-16650/)
lost80s 02-05-2008 01:49 PM
I want to replace my 5" light fixture and put in a smaller 3" recess light -- is there a way to repair the hole in a ceiling that the 5" fixture will leave? I know how to do this with dry wall, but my ceiling is made of a much thicker "sheet roock type" material... what is it and how to I repair a hole?
Cole 02-05-2008 04:22 PM
Can you post any pics of your thick ceiling material?
AtlanticWBConst. 02-05-2008 06:09 PM
It's repaired with Drywall tape and compound. Basically, you have to slowly fill in the hole. After several coats and sanding, you draw out the hole size desired, then score the line with a utility knife.
Last, cut out the shape with your utility knife or router.
lost80s 02-08-2008 12:42 PM
ok thanks - do you have idea what material ceilings are made of tho? It is much thicker than dry wall (like double the thickness) - but I can tell the material is the same.
wolffhomerepair 02-09-2008 05:39 AM
Sounds like plaster and plaster board. Usually about 3/4" thick. I just patched some of this last week. Atlantic is correct. Same technique as drywall.
