Removing X Support Between Ceiling/floor Beams - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 11:39 PM   #1
Rewards Points: 1,062
removing X support between ceiling/floor beams
I would like to remove some of the pictured X supports between my ceiling/floor beams in order to clear way for setting sisters for leveling the beams flush before sheetrock. I was wondering if it is safe to do so or should i perhaps leave them and put two sister dashes on either side of the X which would be less convenient.
Old 06-17-2012, 04:35 AM   #2
DIY staff
Rewards Points: 7,174
Pull them--add your sisters--then replace with solid blocking. Use the drops from cutting your sisters,if they are long enough.
Your house will not fall down when the cross blocking is removed.
Loneframer has done a lot of research on blocking and cross bracing--if he speaks,listen.--Mike--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
amakarevic (06-17-2012), mae-ling (06-17-2012)
Old 06-17-2012, 02:29 PM   #3
that's what i thought. they do not seem like they provide a heck of a lot of support, really
Old 06-17-2012, 04:46 PM   #4
Rewards Points: 502
They don't. They are intended primarily just to stop the joists twisting sideways. In doing this, they also help the joists to work together better, helping to share the load between each of them.
As advised previously, your house will still stand without them; take them out to double the joists, and then replace with solid blocking from the offcuts.
tony.g is offline   Reply With Quote
The Following 3 Users Say Thank You to tony.g For This Useful Post:
amakarevic (06-17-2012), mae-ling (06-17-2012), oh'mike (06-17-2012)
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
removing support post on deck that was to be used to support hot tub steelman50 Carpentry 2 09-07-2011 06:22 AM
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 07:11 AM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 06:11 AM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
