Removing Window, Need Suggestions To Eliminate Eyesore!! - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 07:35 AM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
Removing Window, need Suggestions to eliminate eyesore!!
I am remodeling a room in the second story of an older farmhouse. The remodel plan includes the removal of the window in the photo.
I will eventually be residing the complete house, but it could be a couple years. I am looking for suggestions on how to make it look somewhat attractive while in the waiting period.
In other words i just don't want to put a piece of plywood over it
Any ideas out there please.
Thank you..
HandyDave is offline   Reply With Quote
Old 01-13-2013, 08:50 AM   #2
Rewards Points: 14,306
What's on there for siding now?
I'd just remove the siding to below the window and side right over it.
Old 01-13-2013, 09:00 AM   #3
Demolition Mode
Rewards Points: 129
The siding on there is aluminum its about 6 inches It was installed in the mid to late 1970s with a wood grain design. I am not having much luck finding siding that matches..
Old 01-13-2013, 09:04 AM   #4
Tryed any real siding supplys, not box stores?
Old 01-13-2013, 10:16 AM   #5
Rewards Points: 240
who cares if it "matches". just get the same size and color. your just going to replace it anyway. don't fret over it. i would be more concerned about it sealing properly.
Fix'n it is offline   Reply With Quote
Old 01-14-2013, 11:55 AM   #6
Rewards Points: 454
You could put some wood around the windows.Than you might not have to take the siding off just take a saw and cut it.
scottktmrider is offline   Reply With Quote
Removing window from detached garage HELP mjkpainting Carpentry 9 08-02-2009 06:19 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Any suggestions: about to throw my toilet out the window atomicboy Plumbing 8 09-14-2006 05:09 AM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 05:01 PM
