-   -   Removing Window, need Suggestions to eliminate eyesore!! (http://www.diychatroom.com/f15/removing-window-need-suggestions-eliminate-eyesore-168974/)
HandyDave 01-13-2013 08:35 AM
1 Attachment(s)
I am remodeling a room in the second story of an older farmhouse. The remodel plan includes the removal of the window in the photo.
I will eventually be residing the complete house, but it could be a couple years. I am looking for suggestions on how to make it look somewhat attractive while in the waiting period.
In other words i just don't want to put a piece of plywood over it
Any ideas out there please.
Thank you..
joecaption 01-13-2013 09:50 AM
What's on there for siding now?
I'd just remove the siding to below the window and side right over it.
HandyDave 01-13-2013 10:00 AM
The siding on there is aluminum its about 6 inches It was installed in the mid to late 1970s with a wood grain design. I am not having much luck finding siding that matches..
joecaption 01-13-2013 10:04 AM
Tryed any real siding supplys, not box stores?
Fix'n it 01-13-2013 11:16 AM
who cares if it "matches". just get the same size and color. your just going to replace it anyway. don't fret over it. i would be more concerned about it sealing properly.
scottktmrider 01-14-2013 12:55 PM
You could put some wood around the windows.Than you might not have to take the siding off just take a saw and cut it.
