Removing Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 04:42 PM   #1
Removing walls
Good day all.
Thanking all in advance for any ideas.
We have just recently purchased a 33yr old bungalow and wish to make main level open concept thh removing all walls around kitchen/dining room/living room.
After speaking with an inspector, 2 handymen and a carpenter (and receiving different answers) I decided to remove the gyproc and see what was under the board.
I'm thinking the wall in kitchen is not load bearing as all 2x4, space between top of wall(with drywall above space) and nothing doubled up other than door frames.
There is a big I-Beam running full length of basement and roof trusses are manufactured (support trusses) according to previous owner.
I'm hoping to not get a structural engineer and am including some pics for the pros to peek at.
Any ideas/recommendations much appreciated!
Removing walls-_dsc1287.jpg   Removing walls-_dsc1288.jpg   Removing walls-_dsc1289.jpg   Removing walls-_dsc1298.jpg   Removing walls-_dsc1291.jpg
stevec1 is offline   Reply With Quote
Old 12-27-2011, 04:50 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
It looks like those trusses are designed to span the total distance so removing the wall is not an issue. I'm sure this is the general consensous among the inspector and the carpenters, is it not?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following 2 Users Say Thank You to titanoman For This Useful Post:
gregzoll (12-27-2011), oh'mike (12-27-2011)
Old 12-27-2011, 04:56 PM   #3
Retired carpenter
The walls you tore down are not load bearing walls.
abracaboom is offline   Reply With Quote
Old 12-27-2011, 05:42 PM   #4
Home Inspector was the first one to say remove any walls on main that we wish.
Thanks Much
Old 12-27-2011, 05:43 PM   #5
Thanks Greatly.
Old 12-27-2011, 05:48 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
The Following 3 Users Say Thank You to Bud Cline For This Useful Post:
AndyGump (12-28-2011), Big Stud (12-27-2011), gregzoll (12-27-2011)
Old 12-27-2011, 07:02 PM   #7
Rewards Points: 6,652
Thanks Much
That is like listening to the kid at Mickey D's telling you how to fix a gourmet meal, or going to Lowe's and having one of the kids stocking the shelves there tell you how to build a house.
The Following User Says Thank You to gregzoll For This Useful Post:
woodworkbykirk (12-28-2011)
Old 12-27-2011, 07:09 PM   #8
Too Short? Cut it Again!
Yup. Save a few pennies and definitely do not call in a structural engineer or an architect. Trust the box store apron people more than any others.
Just out of curiosity. Why did you buy this place if your goal was to strip it of its inherent character?
Old 12-27-2011, 07:26 PM   #9
sdsester, I would have at least done it also. The worst thing is to cut the Kitchen off from everyone else, plus they are probably if you measured it, looking at a very small Kitchen space. When we get our upstairs built, I am taking out the wall between our living room and the front bedroom to open that up. I think that the OP place would look great once done, and would like to see pictures of it after they are done.
Old 12-27-2011, 08:24 PM   #10
retired union carpenter
Send a message via Yahoo to coupe
looks like structural trusses, to me. though I may run a 2x6 or 2x8 strong backs down both sides to be safe.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-27-2011, 08:38 PM   #11
I've said it before and will say it again. Architects are not just for the rich. This project looks like some inspector or agency is going to want to see drawings before passing it. An architect called in now is going to save loads---maybe tons of money and aggravation on this project. Of course orange and blue apron folk at box stores have the same capability.
Old 12-27-2011, 08:41 PM   #12
Come on Coupe. The structure looks fine but do you or I have a clue as to what, for example, it all sits on? You sure you want to add 2x6 or 2x8 timber on the edges if there are but foam cups for foundations support? I assume given the images of the trusses their is a real foundation. Haven't seen it though. I sort of hate these post where we only get to react to the immediate parts of a project without a look at the real bones of a house.
Old 12-27-2011, 11:04 PM   #13
Too Old
Looks to me like they are 2 point trusses.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 12-28-2011, 08:00 PM   #14
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
ok number one... big box store employoyees are normally useless when it comes to asking questions about removing structure... especially the young ones. secondly without them seeing what you doing they have no way of knowing what exactly is there.. this is why there are professionals such as myself.. i do this sort of thing on a regular basis and when i do we have a engineer come in and take a quick look at the start, then we remove the drywall and plaster to expose the framing and then the engineer comes back for a closer look only then can you say yes or no to removing walls without putting in beams.
now no more ranting.. based on what im seeing there it definitely looks like you have clear span trusses. it also clearly shows that the wall you want to take down was put up after the fact as the drywall is installed over top of it by the looks of things
woodworkbykirk is online now   Reply With Quote
Old 12-28-2011, 08:58 PM   #15
Retired carpenter
You don't need a permit or an inspection to remove partition walls like these. The OP is welcome to spend money on an architect, but the fact that those walls don't go all the way up against the trusses leave no doubt as to whether they bear any loads or not (not). Those partition walls were framed correctly: trusses should not have walls up to them to "help" with bearing their load. I think that if you did, the trusses would become indeterminate systems (or something like that) and you would not know any more which members of the truss are in tension and which are in compression.
Framing Garage walls and removing door Ziggy CS Carpentry 4 12-10-2009 06:08 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 08:50 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 07:31 AM
